Incessant, Periodic, DING!
Old Jun 23, 2008 | 07:07 AM
MiamiDave's Avatar
OK, so my 2001 Expedition had this periodic ding...so I went for the green wire from the ignition, and cut it. I also checked the ignition connection contacts-all good.
Thought it worked for a few minutes, but now everytime I turn on the engine on, it goes through a series of five beeps, five times (I think), and then generally goes away. No warning lights.
While the wire I cut changed something, it has not stopped the beeping. Any other suggestions (other than a mech)...?
Old Jun 23, 2008 | 03:49 PM
chiefFX4's Avatar
do you fasten your seatbelt before you start the truck?
Old Jun 23, 2008 | 04:06 PM
roushstage2's Avatar
What did it change? I think the green wire is for the tach?
Old Jun 23, 2008 | 11:57 PM
projectSHO89's Avatar
You must have cut the wire for the airbag warning light or the bulb failed coincidentally. You are now hearing the redundent alarm for the airbag system.
Probably would have been a good idea to identify the reason for the ding instead of amputating wiring....
Steve
Old Jun 24, 2008 | 11:29 AM
2stroked's Avatar
Steve
Very true, but if you cut enough wires, that darned ding is bound to stop!
Old Jun 24, 2008 | 11:53 AM
scott.joyner24's Avatar
LMAO! Yeah it will stop the ding eventually. And the truck! Sorry, that was just too funny to let go. Maybe think about reattaching the green wire.
Old Jul 5, 2008 | 10:41 PM
MiamiDave's Avatar
The wire I cut was from the info I gleaned here.
After the cut, it changed the past periodic "ding" to a mandatory, start up ding, though it will do it every now/then while driving too...
Old Jul 5, 2008 | 11:06 PM
Raptor05121's Avatar
Its Ford's new annoyance package. Brings you insane enough to bring it in to the stealership so you spend $300 to have it turned off only to be automatically turned on in 3 months
