switches
Old Feb 24, 2008 | 09:24 PM
aaron150's Avatar
switches
im workin on rewiring my extra reverse lights into auto through a relay but i still want to be able to have them on when in park. can i use a on/off/on SPDT rocker switch like this,
power from reverse-----one side
power to relay----------center
power from battery-----other side
or do i need a different switch
thanks aaron
Old Feb 24, 2008 | 09:54 PM
06 SANDSTONE's Avatar
thanks aaron
I've been looking at this and im sure it will work . With the switch in the up position everytime your reverse lights are on the aux. lights will be on . With the switch in the down position . Power from your battery will also close the contacts on your relay . In turn turning your lights on . Sounds like a good set up. I like the way you think . Anyone could just throw in a single pole toggle switch . Your way is much better . Lets us know how it turns out.
Old Feb 24, 2008 | 10:12 PM
subford's Avatar
Here is a diagram for you.
Old Feb 25, 2008 | 05:00 PM
aaron150's Avatar
Thanks for info and diagram!!
ive found the reverse light wire from a picture on here. but how do i get the kick plate by the hood latch off? and where can i find a park light wire on the inside? or what color would it be?
im goin friday to get the relay and switch but im gonna get the wiring done before.
thanks
Old Feb 25, 2008 | 09:17 PM
subford's Avatar
The parking light wire comes from the main light switch and is a Brown wire.
Old Feb 25, 2008 | 09:47 PM
aaron150's Avatar
THANKS!!! im gonna start wiring tomarrow night.
Old Feb 26, 2008 | 08:13 PM
aaron150's Avatar
http://www.partsexpress.com/pe/showd...number=330-073
has anyone order from partsexpress.com??? they have the relay i need for $1.50 compared to the $7 radioshack wants. anyone had any luck( good or bad) with them????
thanks aaron
Old Feb 26, 2008 | 08:18 PM
subford's Avatar
thanks aaron
I would get one from an auto parts store.
Old Feb 28, 2008 | 01:15 AM
mc2912's Avatar
thanks aaron
just finishing mine up... did it the same way... just need to figure out how to wire the switch so it lights up when in the "on" positions. i could not have done it with out SUBFORD's guidance thanks!
