warning alert stays on when door is open!!!
Old Feb 14, 2008 | 10:08 PM
solidgould's Avatar
Without the key in the ignition, and the headlights are off, the warning sounder continues to go off once the driver door is open!! any ideas? I'm leaning toward ignition switch or some sort of relay.
Old Feb 18, 2008 | 12:36 AM
SSCULLY's Avatar
Which warning is this for, headlamps or key in ign ?
Old Feb 18, 2008 | 12:51 AM
solidgould's Avatar
it is the key ignition warning, which leads me to believe that it is an ignition relay.
Old Feb 18, 2008 | 01:33 AM
joshmac4.6's Avatar
Well the warning chime is part of the GEM module, if it was the relay all the lights and everything would be on, the chime works buy grounding a ckt that runs into the switch the wire is black with a pink tracer to the GEM. I would try tapping the switch assembly and so on if you don't want to replace the switch you can unplug the connector, im looking at a diagram and it appears to be the only wire in the connector, hope this helps
Old Feb 18, 2008 | 09:27 AM
SSCULLY's Avatar
If this is happening without the key in the ignition switch, the tab got broken off ( happened on my 2001 ).
Here is the thread that I used to cure this, look for JMC's reply to thread, describing the removal process.
https://www.f150online.com/forums/sh...=remove+switch
If you want another route, this is disconnecting the indicator that the door is open :
https://www.f150online.com/forums/sh...d.php?t=176323
This is for those where the switch is operating correctly, but they want the door open with the key in.
Good luck
Old Feb 18, 2008 | 05:33 PM
teachertug's Avatar
What if it just chimes once? Mine will chime once when I open the door.
TT
Old Mar 25, 2008 | 12:38 PM
Booker Noe's Avatar
My dad has a 1997 f-150 and when the drivers door only is open without the key in the ignition, the chiming noise goes off until the door is closed. He has replaced the ignition tumber with a new key from Ford and that hasen't helped. Any suggestions???? Thanks
Old Apr 9, 2008 | 09:28 PM
solidgould's Avatar
its realy easy
ok to stop the door chime when the key isn't in ,, you must follow these steps,,,trust me it worked on my 97' F150...
-turn key to on position (don't start it)
-under the steering column, there will be 2 holes next to each other.. the one without a screw in it,, use a flashlight and locate a little button looking plunger inside the hole, now use a small screwdriver and push in on the plunger.
- that will release the ignition cylinder ( the part the key goes in). now with it still in the on position, you can wiggle out the ignition cylinder, remember to keep pushing in on the plunger,
-once it is out, there will be a metal tab inside the hole the cylinder came out of. remove the tab(it should be connected to a wire) , and tuck it between the plastic column cover and the wheel housing. this will make it impossible for the door chime to work!
any more concerns or questions feel free to contact me!
