Fog lights on with your High beams
Hey guys I got the solution you've been looking for if you want your fog lights on with your high beams. Remove the half ISO relay that controls your fog lights. Cut terminal number 1 leaving about a 32nd of an inch remaining. Solder a wire (doesn't have to be a huge wire its only about a 1/4 of a volt, I used 22 gage wire) to the remaining piece of the number 1 terminal, get the wire insulation as close to the terminal as you can to avoid accidental shorts. Place the relay back in its spot and ground that wire you just soldered.
ENJOY!!
I would love to be able to use fog's and high's at the same time. We have a house in the interior of BC and the main highway is really dark at night. The farther you can see ahead the better.
2 methods, search would have found it. BTW : no need to clip the relay terminal:
https://www.f150online.com/forums/sh...d.php?t=233430
Oh now you tell me.
All the head scratchin, trying to figure out wire diagrams, understand how that relay works. That way would also be a little harder getting that fuse panel cover back on. OH well I gotter now. Thanks again for your help with my previous problems. Don't know how the '05 and '06 main fuse panel was put together but the '08 is all PCB.
All the head scratchin, trying to figure out wire diagrams, understand how that relay works. That way would also be a little harder getting that fuse panel cover back on. OH well I gotter now. Thanks again for your help with my previous problems. Don't know how the '05 and '06 main fuse panel was put together but the '08 is all PCB.Trending Topics
I just installed one of these on my truck, and used the Sylvania SilverStar H1 bulbs for it, and WOW is the only description I can use.
When I turn on the high beams, the distance is quite incredible with this light head design ( reflector and bulb type ).
Although it is designed to look like the grille in the new Mustang, they are not fog lamp reflectors.
ENJOY!!
This is indeed a good mod to make. (and cheap!) But its hardly new. Here is a good writeup that I used when I did my truck
http://members.***.net/kinzerford/F-...og_Lights.html
I have been trying to find that page for about a month now and couldn't find it. I did this mod to my 2005 and couldn't remember how I did it. Thanks anyway, I saved it to my favs this time.
Originally Posted by Shinesintx
Just curious, why do you need fogs and high beams at the same time?
Seriously, I hate how the highbeams - without the fogs - basically kills the lighting up close, immediately in front and to the sides of the travelling vehicle.
Fogs with HB's at the same time resovles that issue very nicely.... especially with correctly aimed/adjusted fogs.
The results are day-n-night.
Couldn't agree more. I am getting ready to add a bullbar with some lights. Hopefully something bright and hot enough to melt the paint off the next jack@$$ thats pulls out in front of me, and if I am lucky it'll be pitch black dark.
Download this JPEG for the modified electrical diagram:
https://www.f150online.com/galleries...028-153912.jpg
