Blinkers
Old Feb 4, 2007 | 01:14 PM
bigdad8214's Avatar
Exclamation Blinkers
Blinkers don't work when I tilt my wheel down, Used to only be at the lowest setting but now only work all the way up. Went to the to try to get harness but they said $530.00. Does anybody know what color wires I can check? Also is there 2 for each side?
Old Feb 4, 2007 | 01:21 PM
check the whole harness around the multifunction switch
Old Feb 4, 2007 | 01:34 PM
bigdad8214's Avatar
do you think it could just be the multifunction switch?
Old Feb 4, 2007 | 11:17 PM
possibly, but ive heard the up and down, could eventually pull wires out of contact on the back of the switch
edit if the brights work both directions i would assume the switch is okay
and were you pricing the entire wire harness, or just the colubm segment?
Old Feb 5, 2007 | 08:51 AM
bigdad8214's Avatar
light's work fine, Just the blinkers. The price was just for the colom.
Old Feb 5, 2007 | 01:03 PM
yah check the wires around the switch, for loose wires first then go from there if that doesnt help
Old Feb 5, 2007 | 08:00 PM
ian51279's Avatar
My old 98 Explorer did this exactly. Turned out to be the wiring harness on top of the steering coulmn. Turns out the plastic locking tabs broke off allowing the harness to separate when the wheel was pulled down. I put a cable tie around it.
Old Feb 5, 2007 | 09:40 PM
bigdad8214's Avatar
I took it all apart hoping it was something that easy. I was hoping that I could check them one at a time to find the bad one. But there are like 50 in that cluster........
Old Feb 6, 2007 | 01:52 AM
yeah but you should be able to check around the end of the multi function switch tho. maybe only 20 wires for the switch
