New Battery Suggestions?
The same company makes Motorcraft, Sears DieHard, & Interstate - Johnson Controls. They're actually the same battery, and they're all the best. Don't buy the crappy ones from the zone, or WM. Any dealership or Sears should sell you a good one for $80+tax.
IMO, Optimas (also made by Johnson) aren't worth the money, but that's a WHOOOOOOLE other topic, and you can find it by searching.
I suggest you not use a Walmart Everlast.
They are also made by Johnson Controls. Most likely at a lesser quality.
Everyone I ever had across all the vehichles I have , have been lost to bad cells.
Go with the MC 750 large capacity and you won't be dissapointed.
Originally Posted by ScrewedUPF150
A 750 CCA Motorcraft with 3 year replacement and prorate after that can be had for bout $89.95.
Go with the MC 850 large capacity and you won't be dissapointed.
optima all the way, got the yellow top because my truck sits around wile i leave the country all the time (Marines), every time i get back i reconect the battery and go, no charging nothing 8 months of sitting there and it will start every time.
I put in a Walmart Everlast when my original one took a crap. I put one in my old Explorer too and didnt have any problems with it. My Walmart battery was bigger than the original one so I couldnt use the stock cover. Plus its 850 CCA and 1000 CA with 3 year replacement.
Originally Posted by Steve83
Optima's own published testing shows that they respond WORSE to deep-cycling & long periods of inactivity than "normal" batteries.
I call BS.
Until you prove it..and I would love to see a company that says it's product is inferior to the competition...that would set new standards in marketing! If you can explain the logic of your statement, without even trying to prove it, I'd appreciate it.
http://www.optimabatteries.com/publi...cal_specs.html
This site used to show a LOT more data than it does now, and that's where I saw it. Don't believe me? Fine. Believe the people who say "Optima is the BEST!!!
" without any supporting data. It's your truck & your money. Spend it on whatever you like.
http://www.dcbattery.com/optima2.html
" without any supporting data. It's your truck & your money. Spend it on whatever you like.http://www.dcbattery.com/optima2.html
@($100)
