Installing Codealarm CA-130
Old Mar 16, 2006 | 04:06 PM
F150_Sweden's Avatar
My new alarmsystem in on it's way to me.
My truck has no previous alarmsystem installed, but it has powerlocks and powerwindows. (XLT)
Has anyone installed this alarm and knows wich wires go where?
Old Apr 14, 2006 | 07:39 AM
Angry
All done (almost)
everything is installed and is working fine exept one thing.
When the car is locked and the alarm activated, it takes about 30 minutes (have not timed it) and then the alarm suddenly thinks someone is breaking in.
When i reset it, it indicates that the door ajar sensor has been triggered (same sensor every time)
Have i missed something or is my alarm defective?
Old Apr 14, 2006 | 09:17 AM
SSCULLY's Avatar
From the Ford PowerCode Troubleshooting guide :
Q – Alarm goes off for no reason?
- Check the Attempted Theft Alert in the owner’s manual. Once you know what zone triggered the system then you will know what wire or sensor to check.
Have you checked the connection to the door ajar ( forget which is used for this ), to see if it is connected correctly ?
This is the URL, if you don't have it already for the info about, and some other docuements :
http://www.gemsen.com/ford/
If you want to drop KCAutosound ( Travis ) an email, he is very helpful, as he does these all day long for Ford.
You can get to him directly at : http://www.kcautosound.com/
The other thing you can read through the 204 threads that come up with Ford Gold Remote Start and see if any of this offer anything. I did find someone made a reference to needing Diodes for the door triggers ( WTF ? )
https://www.f150online.com/forums/sh...d+Remote+Start
I have no idea what that is about, before you go doing any thing like this I would email / call Travis first.
Old Apr 14, 2006 | 04:13 PM
I think i solved the problem.
I connected the 10/B wire and after that the alarm has not gone off.
Old Apr 16, 2006 | 12:45 AM
KCAutosound's Avatar
is that 10/B called a pull-up wire? I was trying to find a CA-130 manual but it's somewhere in the pile of stuff since I moved my office to make way for the baby's room.
For some of you that don't know....
Some vehicles have a battery saver mode that will pulse your door trigger/dome light wire thus falsing the system. The way around this is to connect a 10K resistor to your door trigger wire. Basically connect one side of the resistor to 12 volts and the other side to your dome light circuit.
The code systems at least the CA-630 and CA-530 have a 10K pullup wire that you have to just connect to 12 volts and it will do this for you.
Old Apr 26, 2006 | 02:25 PM
Smile
Yep...
That was the pull-up resistor wire.
