Ding Ding Ding Ding Ding
Old Mar 15, 2006 | 01:55 PM
4wheels8strings's Avatar
How do I stop that annoying noise!!! How do I disconnect it? It is driving me insane.
Old Mar 15, 2006 | 02:49 PM
Kool Aid's Avatar
Remove the key.
Close the door.
Old Mar 15, 2006 | 03:31 PM
SSCULLY's Avatar
Are you talking about with the key in the ign, or anytime the door is open ?
The reason I aks, is my '01 only did it with the key in the ign, with the door open, but after a front end hit, it would do it any time the door opened.
Turned out to be the part you remove in the tumbler, broke off, and was laying in the bottom of the channel, making contact all the time.
Here is the thread that JMC describes how to remove the chime indicator, which worked like a top for removing the tumbler for me, and then once I had it out, I saw the broken part in the bottom of the channel, pull that out, put the key back in, and all was good.
Old Mar 16, 2006 | 11:25 AM
I like to listen to the radio with the door open sometimes. While working on the truck etc. Sometimes I drive the truck without a seatbelt, around the farm for example. I'd like to disable the chime, I dont need the truck to tell me to buckle up. You mentioned a thread, how about a link?
Old Mar 16, 2006 | 11:54 AM
Check the owners manual, seems that I recall a procedure to turn it off.
Old Mar 16, 2006 | 01:09 PM
SSCULLY's Avatar
I like to listen to the radio with the door open sometimes.While working on the truck etc.
That is a problem, the Thread below is only for the chime indicator when the key is in the IGN and in the off position. If you want to try to cut the wire to the GEM for the chime, here is one for your rang ebody style, should be the same as the '03.
https://www.f150online.com/forums/sh...d.php?t=141211
For your MY range, all I did on my '01 is unplug the 2 wire connector to the seat belt. It will stop the seat belt chime, the same way the manual tells you to. This has no effect on the airbag or the seatbelt tensioner. This I know for a fact, I crash test dummy'd it out myself
Don't know why I did not paste it in before ?? just stupid I guess, I remember searching for it with keyword=chime and S/N=JMC.
https://www.f150online.com/forums/sh...d.php?t=112508
Good luck with it, let us know if you need anything else. I don't have time to confirm for your MY if the post from JMC is the same 100%, but for the most part MY '99 to '03 are pretty much the same harness color codes.
