key in ignition door chime
Old Dec 31, 2003 | 04:43 PM
billl's Avatar
Question key in ignition door chime
Can anyone tell me how or if the chime can be turned off when the key is in the accessory position and the doors are open? It sure would be nice to be able to listen to the raido without that annoying chime. 2003 f!50 xlt Please help.
thanks
Old Jan 1, 2004 | 09:49 AM
projectSHO89's Avatar
You have to identify your truck. We are not psychic and there are model year differences.
Steve
Old Jan 1, 2004 | 11:33 AM
billl's Avatar
Sorry its An f150 XLT 2003
Old Feb 10, 2004 | 02:54 PM
Atomic's Avatar
Door chime - disabling
Steve
Don't be a JERK. If you're not gonna answer the question or reply with amplifying info do us all a favor and SHUT UP.
I'd like to know how to disable the POS door chime too. My '04 F150 chime is integrated in the instrument cluster. There may be a code or wire cut that can be done to disable it.
For now I turn on the ignition without starting it. Probably not great for the ignition, but does the trick.
If I figure it out I'll post it here.
Old Feb 10, 2004 | 03:20 PM
JMC's Avatar
JMC
25 Year Member
According to my manual If you look along the steering column there should be a brown connector with 6 wires. One of then should be Black with a Pink stripe. This should be the lead to the ingniton key warning switch. The switch grounds a signal from the GEM when the key is in the switch. Put a toggle switch on this circuit and turn it off when you want to turn off the chime.
Regards
Jean Marc Chartier
Old Feb 13, 2004 | 06:24 AM
fejetmech's Avatar
Simply rotate the door latch shut while the door is open , the swith is in there. Just dont forget to release the latch before you slam the door shut or you will quickly remember like I did.
