Obd Ii Scanner
Old Mar 1, 2006 | 05:31 PM
robbycensei's Avatar
Obd Ii Scanner
Can someone recommend a good scanner?
And what is the difference between "Generic OBD II trouble codes" and "Manufacturer-specific OBD II trouble codes"?
Old Mar 1, 2006 | 05:41 PM
goslow's Avatar
www.scangauge.com but it does a whole lot more
As far as codes, it just reads the codes and you have to go to a web site to look up what they actually mean.
Old Mar 1, 2006 | 06:12 PM
98Lariet4x4's Avatar
You gave too little info. After your question, our question is: How much do you want to spend? Personally, I own, use, and highly recommend http://autotap.com. It is well woth the money. Mine paid for itself in about a year, not including the money I have saved for friends.
Old Mar 1, 2006 | 07:00 PM
Bluegrass's Avatar
Don't worry about the differences in code.
You deal with the codes' outputted from your truck.
Hint,,,,their mixed!
Old Mar 1, 2006 | 09:13 PM
tuckmtt's Avatar
Can
If you have an 04 or newer make sure the scanner is CAN compliant otherwise it will not work.
Been there, done that.
Old Mar 2, 2006 | 07:52 PM
Well, the reason I asked about code differential is that the Actron CP9135 reads/clears all "generic codes" and the Actron CP9150 reads/clears all "generic and manufacturer specific codes" with a $250 +/- difference at Autozone (buy today) or Ebay (buy/receive in couple weeks).
Actron is the one Autozone uses and sells, but I've gone to two different AZ's and received two different code readings in a week. Which is why I want my own.
Thanks for any input.
Old Mar 2, 2006 | 08:15 PM
Bluegrass's Avatar
The difference between the two is Generic codes are mandated by the feds to be used for emmisions related operations on all vehichles.
The manf codes are unique to the vehichle combination.
An EGR code is the same for nearly all makes except for more resolutuion using extra codes where they choose to do so; where many failure codes for a 10 cylinder engine and it's transmission would not be the same for another make or model 4 cylinder etc.
Both scanners should read out all these codes except those in the second layers for the drive train b and c codes that are specific to the mfger, combinations, and require a hi end scanner.
There are ABS brake coding, suspension codes and a host of others that you cannot read with a common scanner.
Old Mar 3, 2006 | 01:05 AM
SSCULLY's Avatar
2nd the AutoTap. Upgraded my old copy in DEC-05 for the newer CAN.
I have been using it for about 3 years now, and it works great. Nice being able to datalog info from the engine and do playback as well.
Had an Actron that I got sometime ago, gave it to Dad when I got my 1st copy of AutoTap. It worked, just not as nice.
Larry uses AutoX-Ray and likes the features of it, that does not require a laptop like AutoTap ( got 3 to choose from, not a problem for me ).
