how to tell if keyless entry is installed
Old Dec 12, 2003 | 08:37 AM
99-150's Avatar
I recently purchased a '99 XLT. The truck has power locks and the factory anty-theft system...is there some way to tell (maybe from the VIN?) whether the truck also came with keyless entry?
Thanks!
Old Dec 12, 2003 | 10:31 PM
Rockpick's Avatar
Moderator &
I'm 99.9% sure that it was standard equipment on a 99' with power locks.
Old Dec 14, 2003 | 02:59 AM
Mr_Bentwrench's Avatar
cycle the ignition 5 or 8 times off then on stopping on on when you hear the door locks cycle. if door locks cycle you can go buy a key fob and program it by cycling the ignition till locks cycle then hit any button on transmitter locks will cycle again then hit the button on any other transmitter you have. then remove key locks will cycle again to exit program mode. then everything should work.
remember when you program key fobs to do all of them at the same time because it will erase the old transmitter codes and save the new ones you use.
Old Dec 15, 2003 | 09:42 AM
99-150's Avatar
when i cycle the ignition, do i actually need to start the truck, or just turn the key to the 'on' position?
Thanks!
Old Dec 15, 2003 | 12:45 PM
sk8inrj1's Avatar
just to the "ON" position
Old Dec 16, 2003 | 10:05 AM
braygor's Avatar
okay, maybe I'm an idiot (can't be that bad though, i didn't buy a chevy!) but I tried cycling off to on, and didn't get the locks to cycle. Maybe I don't have the keyless entry, but I want to be sure before I give up and buy an aftermarket system. Is there a certain amount of time I should leave the key in the on/off position before cycling to the next? I waited about two "dings" each time in the on position, and an equal amount of time in the off. Any other tips/tricks for trying this?
Old Dec 16, 2003 | 02:32 PM
99-150's Avatar
that post up there is mine...I made one login on a computer at work, and forgot to change it to my new login name I made at home...maybe I should be driving a chevy Any additional information on proper technique for cycling on/off is appreciated.
Old Dec 18, 2003 | 12:20 AM
B-Man's Avatar
Cool
I found this thread when I was working on my truck several months ago...
...and it worked.
