Electrical
Old Mar 5, 2003 | 08:21 PM
078368978's Avatar
Electrical
Any one know how to disable the interior and bed lights when the doors are opened. Am getting sick of being lit up like a Chrismas tree every time I open the doors. Thanks
Old Mar 5, 2003 | 11:26 PM
je3169's Avatar
the only way i know is to pull the fuse just make sure that there is nothing else on that fuse.
Old Mar 6, 2003 | 01:41 PM
stantd1's Avatar
If you can find somewhere in the wiring harness, the wires that go to the door switch, cut one of them and tape it off. That way you can still manually turn the lights on when you want to. If you never want to use these lights, I'd take out the bulbs. Problem with pulling the fuse is that there may be other stuff on the same fuse.
Dave
Old Mar 6, 2003 | 05:05 PM
JMC's Avatar
JMC
25 Year Member
Need year of truck & tril level, ie 1997 XLT
Regards
Jean Marc Chartier
Old Mar 7, 2003 | 10:17 PM
078368978's Avatar
Electrical
Thanks to everyone for the replies. I tried looking for an exclusive fuse with no luck. Pulling the blubs is not an option because I want to turn them on when I want to, just not every time I open the door. The truck is a 2000 Lariat. Again thanks
Old Mar 8, 2003 | 10:58 AM
JMC's Avatar
JMC
25 Year Member
In the Central Junction Box, fuse panel just below and to the left of steering wheel, there are 2 connectors feeding it. The connectors have 34 pins each. One has 22 wires, Connector 242, and the other one has 24 wires, Connector 243. The one with 22 wires should have 2 wires that are Black with Light Blue stripe. These 2 wires feed the interior lights. They should be almost side by side.
Jean Marc Chartier
Old Mar 10, 2003 | 11:08 PM
078368978's Avatar
Jean: Thanks a lot for the info. When it warms up later this week. I'll try it. Bruce Chamberlin
Old Feb 10, 2008 | 08:18 AM
wake251's Avatar
Disable automatic interior lights?
Did you ever get this to work on your 07? I also have been looking for a way to disable the interior lights from coming on when you open the door. Someone said the owners manual tells you how to do it but I did not see it in mine. I know you can just turn down the dimmer switch all the way, but you would would be constantly turining it up and down at night. Up when you drive and down just before you open the door.
Old Feb 11, 2008 | 09:36 PM
colport833's Avatar
black with blue stripes
Jean...would they be the sames ones that feed the cargo lights?.....do they run from the dome light back to cargo light............where do they run from the panel?
Old Feb 12, 2008 | 10:35 PM
tmd07's Avatar
In my 2006, I can just rotate the dash light dimmer wheel all the way down until it clicks off. Shuts of the interior and bed lights.
Old Feb 13, 2008 | 03:04 PM
GIJoeCam's Avatar
Not on a 2000, but thanks for playing.
Can't get the schematics up at the moment... not sure why...
