question about gryphon monochrome screen
Old 05-11-2012, 09:15 PM
raggidy tom's Avatar
hey i tried to post this on PHP's forum but haven't been activated yet. heres my problem. When I plug it in to the obd port it turns on, gives me the terms and conditions press enter to agree menu. (pressed enter) Then shows the menu make sure key is on but don't start. (Turned key to on). Calibration info ECM:RXAP9B6 press enter to continue (pressed enter, heard a click) nothing happens. (pressed enter again and no click is heard.) that is as far as it goes. What can i do to fix this? To me it sounds like I may have to fork up $75 to unlock it.
Old 05-11-2012, 09:33 PM
sam1947's Avatar
Does it go back to the menu or what ? After you press 'enter' the second time it is supposed to go to the PID readout ie:...temps, rpm, volts, or whatever the display is set for. It does not do any programming at this point.
Old 05-11-2012, 09:57 PM
negative. After i press enter the second time the screen still reads the hex code and freezes there. I've used the programmer for almost a year now and I went to basic training and while i was gone my parents disconnected it because it was running the battery down. Now when i reconnect it this is what happens.
Old 05-11-2012, 10:14 PM
yrsdhzxgfncm
Old 05-11-2012, 10:52 PM
sam1947's Avatar
Better get hold of Bill at PHP on Monday ...
Old 05-12-2012, 07:44 AM
Longshot270's Avatar
Doesn't sound like it is locked. When was the last time you had your battery checked. These programmers do all kinds of funky things when the battery is weak.
Old 05-12-2012, 08:25 AM
sam1947's Avatar
^^ good point.....make sure the battery is fully charged.
Old 05-12-2012, 09:07 AM
Originally Posted by longshot270
doesn't sound like it is locked. When was the last time you had your battery checked. These programmers do all kinds of funky things when the battery is weak.
x3!!!
Old 05-12-2012, 11:46 AM
ok i just checked the battery it is fine. I also checked fuses related to the PCM and they were fine too. I then disconnected my neg terminal for 30 min and i still have the same problem.
Old 05-12-2012, 12:15 PM
JackandJanet's Avatar
Raggidy, it doesn't sound to me like you're connecting the monochrome programmer correctly. The ignition key needs to be in the ON (engine off) position BEFORE you plug the programmer into the OBD port. Is this what you're doing? If not, give that a try. The monochrome Edge/Gryphon needs full power (not keep alive voltage) upon connection to initialize (boot up) properly.
- Jack
Old 05-12-2012, 02:28 PM
JackandJanet, I have tried doing that also and with no result. Still freezes up after i press enter the second time.
Old 05-12-2012, 07:12 PM
The fact that it shows you your ".HEX" code makes me think it's not locked, but if it's a Gryphon (black case) it MAY have custom tunes installed and these will not work on your truck.
But I'm really confused by your description of the way it behaves when you plug it in. Are you sure you have a "monochrome" Gryphon (the screen is all one color - usually green, with black text)? Or could it possibly be one of the newer CS/CTS programmers that show multi-colored displays, both in the startup splash screen and in the analog gauges? These also show you white text against a dark background. Your startup description sounds more like a CS/CTS than a monochrome device.
If you're not sure, can you post a picture? What I can suggest is different depending on the model you have.
- Jack
Old 05-12-2012, 08:49 PM
I'll get pics tomorrow. It's a black box and it has a blue background with black text. When it was working properly i could adjust the hew to make it a red, green, or any color background. I was running a custom tune on it for months with no problems. When it was unplugged it was still running the custom tune. Is it not working properly because it wasn't set to stock before being unplugged?
Old 05-12-2012, 08:52 PM
glc is offline
RECHARGE your battery and get it load tested.
Quick Reply: question about gryphon monochrome screen
