Need Mathmatical Genius
Old Jun 19, 2011 | 07:59 PM
sam1947's Avatar
Running NITTO Dura Grapplers 275/70/18, also using a X3 tuner which requires 'revolutions per mile' for tire setting. This tire comes out to be 608 rpm. The X3 settings are in 5rpm increments. Is it possible to figure the setting to include the "3% 'squish' factor" with this set-up ? Or is it even possible with this unit ?
Old Jun 19, 2011 | 08:04 PM
thomabro's Avatar
with 3% it should be 617 rpm
Old Jun 19, 2011 | 08:10 PM
Marc Carpenter's Avatar
Set it at 610 and you will be good. After you hit 40 or so mph its out the window on rpm anyhow.
Old Jun 19, 2011 | 08:34 PM
Windsor's Avatar
If it's revolution per mile data from the manufacturer, it already has "squish" factored into it. Just enter it into the programmer.
Old Jun 19, 2011 | 08:40 PM
Windsor's Avatar
Obviously that is not the manufacturer's published rev per mile data. I just looked it up on Nitto's site and it's 625. Just plug that in the programmer and you're good to go. 608 x 1.03 = 626, so you must have used the published O.D. in your 608 figure.
Old Jun 19, 2011 | 09:01 PM
thomabro's Avatar
i used the pegasus calculator to figure it off of the given tire size, and it came to to 617. i used the same calculator for my truck just with a 5% squash and it dead on with both gps and local pd lasers.
Old Jun 19, 2011 | 09:18 PM
sam1947's Avatar
Thanks for all the help guys !! I got the 608 figure from another tire sizing site...I'll plug in the 625 and call it a day !
Old Jun 20, 2011 | 10:28 AM
A good website is www.powerdog.com plug in your tire size and the results will be close....
Old Jun 20, 2011 | 04:25 PM
Sam, to fine tune it, compare the programmer's speed readout with a GPS, if it can monitor vehicle speed.
Old Jun 20, 2011 | 08:41 PM
sam1947's Avatar
I also have a gryphon I am using just as a gauge pod at the moment and a GPS. I plugged in 820 with the X3 and between all three (speedo, Gryphon, GPS) everything was within 1 to 2 mi difference with each other and on occasion they were the same. As stated Thanks Again folks.
