CAI with edge
Old Feb 25, 2011 | 01:35 PM
Bighahn's Avatar
Question CAI with edge
I have an edge cs on a 2007 screw and was wondering what i can do if i get a banks ram air intake. i know that the 5.4 will run lean without a custom tune so is there a way to adjust that with my edge? Ive tried searching for a similar thread and had no luck. Any info would be greatly appreciated.
Old Feb 25, 2011 | 01:37 PM
MGDfan's Avatar
No.
MGD
Old Feb 25, 2011 | 01:44 PM
Bighahn's Avatar
Originally Posted by MGDfan
No.
MGD
Wow thanks! what am I supposed to do then? turn it into a gryphon?
Old Feb 25, 2011 | 02:05 PM
Norm's Avatar
Yes
Old Feb 25, 2011 | 02:20 PM
MGDfan's Avatar
Originally Posted by Norm
Yes
And - absolutely correct.
OP: More info for you .. just a wee sample - there are hundreds more ...
https://www.f150online.com/forums/ch...take-tune.html
https://www.f150online.com/forums/ex...ke-system.html
https://www.f150online.com/forums/ex...?highlight=MAF
https://www.f150online.com/forums/ex...-question.html
==> fave; https://www.f150online.com/forums/20...147-tuner.html
MGD
Old Feb 25, 2011 | 05:24 PM
Veteran: Army
yup
Old Feb 25, 2011 | 06:19 PM
beechkid's Avatar
25 Year Member
The 5.4 flat panel oem filter will flow up to 500 cfm, the cone filter will flow up to 1000 cfm (because of more surface area), the 5.4 engine has a max CFM intake of 480 (sorry but the laws of physics at work here)....if there is any minor adjustment, the pcm will more than take care of it within 50 miles (or more likely immediately after warm-up)
Anyone retailer who states that by merely installing an aftermarket intake will create a lean engine condition is , well......how do I say this.....the PCM and sensors are all designed to track and ensure the fuel mixture is correct and if it's not, it will adjust the fuel mixture up to 10% to compensate....you would have to have a lot of engine performance mods to exceed that or have a real special circumstance of elevation that would create an excessive lean or rich mixture in which case, the oem has e-based solutions for.
Old Feb 25, 2011 | 08:14 PM
expy03's Avatar
Except in open loop; where the settings are fixed. Hence the problem. Especially during WOT.
And the throttle body ultimately has the final say as to how much air enters the engine.
Old Feb 25, 2011 | 09:19 PM
Bighahn's Avatar
Ha. thanks for all the info but now I have people saying two different things. Hmm... what do to?
Old Feb 26, 2011 | 03:21 PM
Norm's Avatar
You are missing a key piece of the puzzle. The problem is not the cfm of the filter. It is the relocation of the MAF on some CAI kits that causes the problem. On the new 3v engine the MAF relies on the location and volume of the intake after the filter for its transfer function. Before 04 on the 2v engines the MAF had its own calibrated volume and was not upset by relocation in CAI kits. The lean condition is well documented in 04 and early 05 motors even with stock intakes. Ford did make some changes after that.
Old Feb 26, 2011 | 03:53 PM
^^^ well stated, Norm, and correct.
Old Feb 26, 2011 | 04:14 PM
mach1mustangman's Avatar
I am now in the market for a tuner, but now I wonder if it would be better to find a CAI as well. I haven't seen any for the new 3v 4.6 that I have in my truck. What are your thoughts about this? I am worried about messing with it to much in fears of it running to lean.
Old Feb 26, 2011 | 04:17 PM
Norm's Avatar
Tuner first. Don't bother with CAI.
Old Feb 26, 2011 | 04:26 PM
There are several out there. I have been looking at Hypertech and Superchips because I don't have a lot of $$ to throw at one at this point. I assume either would be good, right?
Old Feb 26, 2011 | 04:34 PM
Norm's Avatar
I would recommend a device that can load custom tunes even if you do not need them now. Look at the stickies at the top of this forum.
