Custom tunes... varying octanes
Timing adjustments are not really "precise" things (due to manufacturing differences in each engine) and gas octane is not necessarily too exact either. So, it's best to "sneak up on it".
- Jack
I certainly recognize though, that you're not going to get the "best" out of your powertrain with that setup. But, PHP has said there shouldn't be any danger of damage when using the high priced liquid in a low octane tune.
I wonder about A/F ratios too. Would high octane gas have a different stoich than low octane? I know ethanol changes the stoich, but knock inhibitors?
And, I recognize that a tune for power does involve a slightly lower stoich setting than the "optimum".
So anyway, John - now you've got two "opinions"! Each one's probably worth exactly what you paid for them.
- Jack
on
Yer buddy calls you up to come pull a trailer TODAY.....you want to switch to yer 87 tow tune cause you don't have a 93 tow tune and the night before you just topped off yer tank with 93.
You can't go 87 to 93 but with adjusting the timing you can go the other way as J+J pointed out but I do remember that situation was for towing and not performance tunes.
I do agree with Bluejay that it is a big step......
As a general rule of thumb you should always get a tow tune in the same octane as what your performance tune is.
Let's say you run a 93 perf tune 99% of the time......
