87 octane with Gyrphon custom Performance tune
Ordered a Gryphon with 1 custom, 87 octane Performance tune, a couple months ago. Have the gryphon already and the tune is supposed to arrive next week.
I have a question though. What's everybody's thoughts on what octane gas to use with the Gryphon? I'm wondering if I should get another custom tune with a higher octane etc..
Thoughts/Suggestions?
Thanks,
Rob
Thanks,
Rob
Lonestar, you might possibly get enough of a gas mileage increase using high octane fuel with a custom 93 octane tune to justify getting it, but it's really a bit of a hassle to change over. You have to run your tank almost dry on the 87 octane stuff, then fill up, drive home to get the old gas out of the fuel lines and then switch tunes. Then, of course you have to KEEP putting the 93 octane stuff in and if you don't, you really should change back to the 87 octane tune instead of just retarding timing. Also, you might find the 93 octane stuff might give you some hard starting issues in cold weather.
Personally, I have two tunes - both 87 octane. One is for towing. The only time I switch is if I'm going to tow, or quit towing.
- Jack
- Jack
