Edge and towing
While the edge is a great product, and it does give you noticeable gains... There is really no replacement for pure displacement. I have the 4.6 as well and am very happy with it. I have added the edge and am now saving for gears, something you might look into. I have 3.55 gears and will probably go with 4.30's or 4.56's. Gears are usually a less expensive way to go and in most cases will make up for lack of big displacement power.. IMO...
- Jack
I have the tow package with the 3:73 gears it does a good job now I just want a little more for hilly situations
So I wonder if 4.10 gears and custom tunes from php would do the trick. I wish I had found a set up with 3.73's, I am running 3.55's on 33in tires. My edge helped but dono how much ur trying to get out.
I'm going with the edge turner throttle body spacer volant cold air intake and some exhaust quess I'll see if its enough
The throttle body spacer does nothing for an injected engine. Total waste. The CAI needs a custom tune to get much benefit from it. The Edge is for stock intakes. If you want the most out of a CAI, get a custom tuned Gryphon or maybe an Xcal3. You would be paying a big price for a small gain if you put the CAI on with the Edge. The Edge by itself will help a lot. About 20 hp and a lot more low end torque. A custom tune would be even better.
- Jack
