edge tuner questions
- Jack
Hey I got an edge tuner I like it I havent done much with the custom tunes other then just used the three that edge has programed. I think that its maybe possible to damage your tranny if you do a custom tune that is too radical and you dont keep your transmission fluid changed every 30000 miles.
You CAN optionally change some things yourself with a programmer, such as setting the MAX RPM and WOT shift points way too high, and, you can drive your truck like a rail all the time and I guarantee you will shorten the life of your transmission. Changing the fluid isn't going to help much if you treat your truck badly.
- Jack
