Edge causes rough idle
I'm 99% percent sure my Edge is causing a rough idle on my 06 FX4 on level 2. Actually I think the truck runs "rougher" all together.
I've been experimenting the last 2 weeks. Running it with Level 2 and then running it stock. Truck idles so much smoother on stock setting. No idea why. I'm going to run it on level 1 and stock for the next couple of weeks and see if level 1 messes with it any.
I guess it's time to send it off to be Gryphonized. I would hate for the same problem to happen with custom tunes, though.
It idles so rough, sometimes it will make the antenna shudder. On stock tune it's smooth. No antenna shudder. You can just feel the difference.
What sucks is the performance I lose on stock tune, though.
- Jack
Hey,
I had a similar problem with the rough idle on level 3 with Bluejay's mild EDGE mods when I ran the A/C. I moved my idle around in small steps until it went away. I think it was 75 or 100 rpm. Not necessarily the engineered fix, but it works until I go to PHP this fall. Good luck.
I just cleaned the throttle body tonight and switched back to level 2. Haven't had a chance to drive it enough to tell. It's actually random and doesn't idle rough all the time on Level 2. But it was doing it enough to be a nuisance.
