EDGE... what level r u on???
Old Apr 19, 2009 | 11:59 AM
Originally Posted by last5oh_302
I switch back and forth from level 2 to level 3. Just depends on my mood and where I figure my next tank of gas will mostly be driven.
I just switched back to level 3 last night. I also play with different brands of gas. Sometimes I run Sunoco 94 and make the appropriate adjustments (+3 timing), and other times I'll run V-Power from Shell. I put the zero ethanol V-Power in last night and left the timing at zero.
My last 2-3 tanks were run on level 2.
You're not an accountant are you? We don't like change that much!
Old Apr 19, 2009 | 12:58 PM
WVxlt's Avatar
Mines a PHP Gryphon but its only providing me the canned Edge tunes for now. Using level 3 with 93 octane, adjusted rpms and 1.5 timing. Its a Chevy and Hemi eater My friends were indeed impressed.
Would you mind posting all your Level 3 settings? I also have a Gryphon running canned tunes and would like to get the most i can out of it while I wait for custom tunes...
Old Apr 19, 2009 | 01:14 PM
last5oh_302's Avatar
No
FWIW, these are my settings. I started out by using Bluejay's settings from when he had his Edge, but I've adjusted them slightly for personal preference.
Speed limiter- 110
WOT gas- 1.30 for 87 octane level 2, and 1.60 for 91 and up octane on level 3
Shift firmness 1-2 (10), 2-3 (10), 3-4 (8)
shift points 1-2 5250, 2-3 5250, 3-4 4800
rev limiter 5650
timing- depending on octane bump half a point per octane count (87 octane on level 2 and 91 octane on level 3 leave at zero since thoe levels were tuned for that octane)
I think that's it.
Old Apr 19, 2009 | 02:53 PM
rickmb150's Avatar
when switching from level 2 to level 3, do you have to have the tank completely filled with 91+ or can you have like a quarter tank of 89 and the rest 91?...I'm tryin to avoid the potential knock or pinging...
Old Apr 19, 2009 | 03:09 PM
I never have it completely empty. I don't like to run mine that low. I get it to just below 1/4 of a tank.
Old Apr 19, 2009 | 05:07 PM
lvl 3, 93 octane.
1-2 WOT shift 5100rpm
2-3 WOT shift 5100rpm
3-4 WOT shift: 4800rpm
Max rpm: 5600
speed limiter: 200
timing: 1.5
and for display i have RPM, MPH, AVG MPG, and Engine Load PErcentage displayed.
Never tried a 1/4 mile run but my best 0 - 60 was 7.26
Old Apr 19, 2009 | 08:11 PM
WVxlt's Avatar
Thanks last5oh_302 and DarrenWS6. I usually drive around with the 93 tune, but haven't changed any settings other than bumping up the shift firmness and removing the speed limiter. Might have to try some of these...
Old Apr 19, 2009 | 08:36 PM
yetti96's Avatar
Gryphon Level 2 with canned tunes, adjusted max speed to 125. I have yet to mess with the timing and shift points. Tried level 3 twice but not enough to say yea or nay. I know Bluejay swears/swore by it, but I did not experiment too much yet. I must say though my max speed was 120 and that was not fun to hit, so I bumped it to 125.
Old Apr 19, 2009 | 09:35 PM
T&Df150's Avatar
Does anybody know if I can run E85 with my Edge in my 06 F150, and it is a flex fuel truck.
Old Apr 19, 2009 | 10:20 PM
greencrew's Avatar
Yes. I called tech support, and they advised you run level 3 because of the higher octane.
Old Apr 19, 2009 | 10:22 PM
greencrew's Avatar
I'm running level 1 for a while. I was towing all day Saturday, so I changed it to level 2 for the weekend.
Old Apr 19, 2009 | 10:56 PM
You really need to bump the timing at least 1.0 if you are running 93 octane. The program is for 91.
Old Apr 20, 2009 | 12:35 AM
T&Df150's Avatar
Cool, I think ill try it.
Old Apr 22, 2009 | 07:55 AM
radar's FX4's Avatar
i've had mine for about a week and a half now and i still haven't tried level 1 yet.i still haven't seen a mileage increase yet either on my 08 have you? but i have mostly been driving in town. 14.9 is the best so far on level 2.
Old Apr 22, 2009 | 07:58 AM
i've had mine for about a week and a half now, in my 08.have you seen a mileage increase in yours? i'm averaging 12.5-14.9 being the best so far, mostly in town driving. thanks!
