Edge Programmer Help!!
Old Apr 14, 2009 | 06:33 PM
Jr_WaxDr's Avatar
Every once and a blue moon my Edge Programmer will just shut off. I have tried to look for common variables every time it shuts off but it just seem to be at random times. Sometimes i can drive all day and it will never shut off, and other times i will be driving for 10 mins and it will die on me and if i go to try and turn it back on it will just read zeros and just shut back off.
Old Apr 14, 2009 | 06:46 PM
last5oh_302's Avatar
Check the volts on your battery. When was the last time you replaced your battery?
Old Apr 14, 2009 | 07:59 PM
JackandJanet's Avatar
This actually sounds like a loose/faulty OBDII cable connection to me. Make sure both ends are tight and fully inserted.
The cable itself can be faulty too. I know of two that PHP has replaced (free) for their Gryphons. You may want to talk to Edge about this possibility.
Finally, I suppose the wiring into the OBDII port could be faulty/worn - especially in a truck as old as yours. That could easily cause your symptoms.
- Jack
Old Apr 21, 2009 | 10:31 PM
Jr_WaxDr's Avatar
Is there any way of checking this. How much of a problem is it. I was also wondering if it is doing any damage to my computer. Has anyone had this problem before?
