Edge slowing me down
Old Apr 23, 2009 | 06:55 PM
powerz69's Avatar
Do you think you would need custom tunes if you had a MIT not a CAI ? The MIT would be more air then factory, even little more then factory mod.
Old Apr 23, 2009 | 07:57 PM
BlueBulletflech's Avatar
Not sure what you mean by MIT?
Old Apr 23, 2009 | 09:03 PM
powerz69's Avatar
MIT = Modular Intake Tube (aftermarket). I found out anything before the MAF sensor is ok. Anything after like a CAI you will need custom tunes. I just want to clear somethings up before buying a programer.
Old Apr 23, 2009 | 09:31 PM
x_sgs_x's Avatar
Would running 93 Help Correct this lean problem.
Old Apr 23, 2009 | 09:52 PM
Im not to sure about MIT, this is the first time i have herd about them.
Old Apr 23, 2009 | 10:15 PM
powerz69's Avatar
Sorry for highjacking your post.
I do not know to much about a programer, but from what I have read if using a CAI you should use custom settings. If you don't you can end up with a $$$$ bill, more on 04 05 trucks. I would take the CAI off and do the DWV mod, link below, untill you get your custom tunes. If you feel somthing is not right I would not chance it. I would do this mod over anything bought.
https://www.f150online.com/forums/ch...04-trucks.html
Or this one
https://www.f150online.com/forums/ar...4l-engine.html
Old Apr 24, 2009 | 05:33 PM
Ya i have my intake off untill i get my tunes. Its kinda nice not having the drone of the intake
Old Apr 24, 2009 | 09:55 PM
JackandJanet's Avatar
Back to your original question: Does this thing provide a "ram" air effect? If so, I think it COULD fool the MAF sensor and cause a lean mixture. I'm sure the MAF sensor is not set up to detect a super wide range of airflow patterns accurately. It seems to be able to handle the additional air volume from a "Gott's" style intake, but I'd be nervous about anything more, without testing.
- Jack
Old Apr 24, 2009 | 10:47 PM
- Jack
I seem to recall that Bill said air can move past the MAF at such a rate that it exceeds it's ability to record it, thus not adjust. Plus, you don't really get the full benefit of a CAI without a tune that can match the fuel needs with the intake.
Old Apr 24, 2009 | 11:54 PM
powerz69's Avatar
hmm now you got me thinking. I guess it's kinda a ram air.
Old Apr 25, 2009 | 01:50 PM
Looking at the picture, it seems you could be getting a ram air effect at higher speeds.
If I'm not mistaken, the MAF sensor is something like a resistance wire that is cooled by air moving past it. The cooling effect changes its internal resistance and the voltage drop over it is then used to infer air volume. It can't really be TOO sensitive and its range has to be somewhat limited.
- Jack
