no display on my edge programmer...what to do??
Old Jul 17, 2008 | 06:39 PM
crash_lucky13's Avatar
i KNEW you would say that..
Old Jul 19, 2008 | 01:04 PM
*FX4TEXASGIRL*'s Avatar
THanks guys I will go check out that fuse. Makes since cause on my way to baytown back in april i plugged in my transmitter for my phone and A huge spark came out of my cigarette plug. Hope thats the problem if not i will give edge a call. And if that doesnt work i wil may just have to thump it!!
Old Jul 19, 2008 | 01:07 PM
JackandJanet's Avatar
A huge spark sure sounds like a fuse blowing event to me!
- Jack
Old Jul 20, 2008 | 11:09 PM
Thanks guys... it was a fuse that was out. Should have checked that first. But one more question. Do you think i lost any of my settings or is the settings the same and the only thing i lost was the screen?
Old Jul 21, 2008 | 12:13 AM
Cool! (It's nice to guess right for once)!
My next guess is, you have not lost anything. Once the PCM is programmed by your programmer, it "holds" that program until it is reprogrammed.
Plugging your programmer in for driving simply lets you use it as a set of auxillary gauges. It is a "monitor" only. The PCM settings will not change until YOU use the programmer to change them. (This is more than just a "guess" - I'm 99.99% sure of this)!
Glad you have your Edge back!
- Jack
Old Jul 21, 2008 | 10:02 AM
ThumperMX113's Avatar
Once again, listen to Jack and/or Janet on this one. He and/or she know their stuff ...
Old Jul 21, 2008 | 11:36 PM
- Jack
Thanks so much Jack.
Old Aug 7, 2008 | 03:02 PM
Back again about my edge. So i fixed the problem with the fuse. Now my programmer shuts off and a blank green screen displays. I tried to unplug it while the truck is off, I do as it says but as soon as i turn the key over the screen is blank again. Its everyday i have to do this. the other day i did the same as i always do and a blank RED screen appeared. freaked me out a bit so i turned my truck off waited a couple minutes and started but the edge was still just a blank green screen. Sometimes its a blank green screen other times it say evolution and other times it works great. Should I call edge on this one? what do you guys think?
Old Aug 7, 2008 | 03:17 PM
how HOT is in it your truck when your doing this? you two kill me tho my gryphon does that too when it's really hot in the truck..
Old Aug 7, 2008 | 03:37 PM
Well I do notice when its really HOT in my truck the screen looks a little smeared. But it also happens in the morning when my truck isnt so hot.
Old Aug 10, 2008 | 08:35 PM
netspec's Avatar
Originally Posted by Paralyzer
very good point. if u overloaded the lighter circuit with crap that can kill the 12v to the edge.
My display went out last week and yes, it was due to a blown fuse! I have my XM Radio powered from the cigarette lighter. Changed blown fuse and all was well!
Old Aug 10, 2008 | 08:57 PM
Heat WILL effect the display in these screens. I've not had that problem though. In an earlier post, you describe what sounds like an "intermittent" problem and I have no knowledge to help you here.
Possibly, Bill may have some suggestions. But, he's pretty busy right now. I think I'd be bugging Edge for a fix. Sorry I can't be more help.
- Jack
