Edge Evo In California????
Hey all,
Anyone using the Edge Evolution in California? Just wondering if this thing is CARB legal? The statement in Edge's website isn't very specific or helpful. The best that I can get from local dealers is "turn it off before inspection," which doesn't help.
Originally Posted by bangingd
I am using one in CA. I am sure it is not CARB legal but will return to stock before any emissions testing.
Several other writers then claimed they had no problems with the test using their current "tune" and the overall feeling was to not reset it to stock. The opinion was that a tune would actually perform better than stock on an emissions test.
Remember, with the Edge, you can always take it out of the truck without changing the tune, so the testers would not know you were using it. Once it's programmed the PCM, it's just an extra set of gauges.
I'm sure Bill could give you a better opinion on this if he happens to read your post.
- Jack
You might want to be careful with this. An earlier post on a different thread in this forum talked about their truck failing the emissions test BECASE they returned the programming to stock prion to the test. The reason it failed was because there was not enough time between the reset and the test for the PCM to "recalibrate" and clear its "codes". The presence of a code caused the failure.
- Jack
- Jack
I would be curious to see if any of the people that passed emissions testing with tunes loaded are from the Peoples Republic of California.
UPDATE:
Edge had this on the website...
http://www.edgeproducts.com/customer...le.php?csak=33
Hope this helps.
Bill
Hope this helps.
Bill
Thanks for the follow-up. I had caught this in their web sight as well, but it's really not specific to any product. I've since checked CARB's on-line database and found that Edge only has 1 E.O. Unfortunately, it's unrelated to the Evolution. So I guess, as folks have already mentioned, it's a "no go" for California.
