Another edge problem
Old Apr 18, 2007 | 11:09 AM
Originally Posted by sysman_rick
Have you guys considered it's not the Edge ? What about the PCM code ? Have you checked TSB's for driveability problems for your PCM versions.
My 05 F-150 KR Screw runs great on level 2 or 3 with tire/axle ratio/timing changed.
Do not automatically ASSUME it's the Edge causing all your problems.
A very satisfied Edge customer.
Exactly! Same here.
Old Apr 18, 2007 | 11:17 AM
MGDfan's Avatar
Hi.
I think your are partly right.
PCM code yes, but Edge's possible spotty support for specific '06 codes, not the factory tune itself (which appears fine).
Remember - Edge already indicated they were aware of the problem - that's a BIG hint right there.
As indicated by me & others - contact 'em, give 'em yer codes, and keep on 'em!
Or, go buy an X2 & be done with it already !
Do not automatically ASSUME it's NOT the Edge causing all your problems.
A very satisfied TP Xcal2 customer
Cheers
Bubba
Old Apr 18, 2007 | 11:21 AM
Originally Posted by MGDfan
Hi.
Cheers
Bubba
Finally! Glad we got that overwith!
Old Apr 18, 2007 | 11:24 AM
MGDfan's Avatar
My first thought was of you, Jim!
would not want to disappoint...
Cheers
Bubba
Old Apr 18, 2007 | 12:11 PM
hmfic's Avatar
Are you guys loading lvl 2 or 3 stock tune, then going to the custom setting tune?
Just wondering, because when I would always do it, I would go back to lvl 0 or factory tune, then reprogram the truck into a custom tune. I never had any problems going that route.
Old Apr 18, 2007 | 12:15 PM
gilsnuxs's Avatar
x2
I have an '06 as well and I have not had any problems with adjusting any sort of the custom options on any of the levels.
Old Apr 18, 2007 | 12:25 PM
I just go to level 2 or 3, which ever I am wanting, immeddiately do the custom settings, then load.
Old Apr 18, 2007 | 12:26 PM
hmfic's Avatar
Thats what I was trying to say. That works for me, have you had problems doing it that way?
Old Apr 18, 2007 | 12:34 PM
That's what I do. I choose the level I want, then the load previous settings and adjust the timing for the level I'm choosing, then load the custom tune.
Old Apr 18, 2007 | 12:40 PM
MGDfan's Avatar
Ahhh.. the dreaded "User Error" thingy rearing it's head again?
Gotta be one crappy manual LMAO !
I'm giving these guys a little more credit than that !
For the slow ones in the class - NOT the ones having the problem lol - could one of you folks that are having this issue, go do it again - write down each specific step, & post those steps back on here, please?
Cheers
Bubba
Old Apr 18, 2007 | 03:42 PM
MosineeFX4's Avatar
I also always reload the stock tune and then go into custom programming and chose level 3 (or 1 or 2 if you chose) and then enter the parameters I want. I have not had any problems doing this. Of course, my truck is an 04....I do think it is possible that it iis related to certain hex code families. You guys should post your hex codes so people will know.......might help us better understand what's going on. On that note, I am at work and can't remember my hex code?
Old Apr 19, 2007 | 03:36 AM
TennesseeTritan's Avatar
I spent half of the day Sat. trying every combo I could think of, driving the truck to test it,wasting my 93 octane, and nothing worked. There has to be something different with the 06 because look at all the members on the previous page that own a 2006 model, and the ones that say they had no problems owned another model year. There is no doubt in my mind that Ford changed something in the PCM in the 06 model year but, the box my Edge came in includes the model year of 06 so they should have it compatable with my pcm. I am 100% positive user error can be ruled out
Old Apr 19, 2007 | 07:02 AM
hivoltagefx4's Avatar
Have you heard back from Edge yet? I'm curious as to what their response to this is? I've been running the "canned" tunes without any issues and have not tried to customize anything yet, but when I do, I certainly do want to run into any issues.
Old Apr 19, 2007 | 12:54 PM
They e-mailed me back monday and said they were working on an update.
Old Apr 19, 2007 | 01:23 PM
Oh, and it should be out later next week
