just installed Edge Wow!!!!
Originally Posted by DeathMetalTruck
Good to hear you like it. I am gonna pick one up and also have a 2000 F150 5.4...so i've been wondering if they make a good difference on the older 2valve engines. I know they are awesome on the newer trucks.
Originally Posted by josho66
So I should just run it till I have a problem then???
install it and enjoy, before the warrenty is up update it. there is a version code on the back of the Edge, I believe the latest released version is 24, if I'm wrong someone will point it out. most of the updates are for different hex files (newer trucks), some updates are to fix problems with those hex files and some updates improve the programing in the Edge. If your Edge was recently made then it sould be good to go.
Originally Posted by chester8420
Just update it. I've updated mine 10+ times at least. It doesn't hurt it. And a few times, it was MUCH better than before.
I was just concerned about updating it for no reason and then messing something up. Appears that won't happen.
Every Edge thread I read people state the transmission shifts more firm and quicker. Does this effect the transmissions overall life? Don't these transmission stink already as it is? I'm hesitant to get an Edge if it's going to wear out my tranny quickly.
I had to update mine to the latest version. My truck is late 06 and the Edge was made in 02/07. I think it's fine to update. By the way, the guy at Edge said that you shouldn't do anything while programming (open door, turn on/off radio etc.) FYI not sure what it would do but it could interfere with the process.
PB
PB
