Collinite 845 Wax
Old Jan 28, 2013 | 09:12 AM
nate3420's Avatar
Collinite 845 Wax
Has anyone tried the Collinite 845 sealant wax and put a too coat of ICE liquid wax on top for extra shine. I have read some about it and working well but I wanted to see if anyone has tried it on the tuxedo black yet
Old Jan 28, 2013 | 09:17 AM
Gipraw's Avatar
Collinite 845 is a fantastic product. ICE Liquid isn't worth putting on dog crap.
Old Jan 28, 2013 | 09:53 AM
tg150's Avatar
Collinite 845 is a great wax, I'd definately recommend giving it a try.. Normally I use it as an LSP though, usually 24hrs after a good sealant like Poorboys EX-P.
Never used any Ice products..
Old Jan 28, 2013 | 10:07 AM
nate3420's Avatar
so I am pretty good by just applying this and being done. No top coating is really needed?
Old Jan 28, 2013 | 10:53 AM
nate3420's Avatar
i was thinking it would use a Mother's Gold Clay Bar kit first then the Collinite 845. Think that would be good for a Tuxedo Black?
Old Jan 28, 2013 | 01:48 PM
You will need to use something in between the clay and 845 for correction, 845 is not a cleaner wax.
Old Jan 28, 2013 | 02:27 PM
2stroked's Avatar
X2 on that! It works great all by itself and I've posted more than enough pics to prove it.
Old Jan 28, 2013 | 03:53 PM
Gipraw's Avatar
Yes. If you don't have any marring, swirls or the like you want to remove, then clay followed by the 845 will provide you a nice looking surface and some good protection.
Old Jan 28, 2013 | 08:49 PM
nate3420's Avatar
Nope nothing wrong with the paint. It is a brand new truck only 700 miles on it so far. Just want to clay it first to get all the containaments off it from road salt and such before I use the 845 to seal it. Should I wash the truck after claying or just go from clay to wax. What yields best results?
Old Jan 29, 2013 | 09:34 AM
Gipraw's Avatar
Wash, then clay. If you use a QD as your clay lube, there is no reason to wash again. You can go straight to the 845.
Old Jan 29, 2013 | 09:41 AM
nate3420's Avatar
Yeah I am using the quick detail. Ok then that works. Just wash, dry, clay, wax. That's what I'll do
Old Jan 29, 2013 | 11:21 AM
dsq3973's Avatar
Or clay right after you wash while the vehicle is still wet you will use less QD and dry the vehicle at the same time.
I use this trick quite a bit on sunny days to avoid water spots if I can't get the vehicle in my garage.
Old Jan 29, 2013 | 11:52 AM
Glen R's Avatar
I just used it on my Expedition. I used along with Griots #3 polish. Came out pretty well.
