Winter Care/Maintenance
Old Nov 27, 2012 | 09:02 AM
Zander10893's Avatar
I have decided that I will be garaging my truck for the winter in order to help preserve it and protect it from the salt that is used on the roads here in northwestern PA. I have read various articles that give you suggestions on how to keep the truck in good mechanical condition, things to do, etc. However, I wasn't totally buying into everything I was reading. I will have the truck started as frequently as necessary. So here I am, looking to get some insight from you guys. What are some things that I can do in order to keep my truck in great shape mechanically and cosmetically as it sits over winter?
Old Nov 27, 2012 | 10:39 AM
Fully detail it before putting it away. Change the oil, fill the gas tank, and add fuel stabilizer. Park it with the tires on scrap carpet squares. Put a battery tender on it. If you aren't going to be taking it out and actually DRIVING it periodically, don't bother starting it.
Old Nov 27, 2012 | 01:17 PM
Why park on carpet squares, may I ask? To prevent tire flattening from sitting in the same spot? As far as the battery tender goes, I am hesistant to use this because I did this last winter and it shot my battery...unless that was just unlucky timing on my part. Wouldn't starting it help keep the fluids from becoming stagnant? Thanks for your insight!
Old Nov 27, 2012 | 04:07 PM
beechkid's Avatar
25 Year Member
This is all environment & storage duration dependent, but this is what our family has done with any vehicles we have stored for the past 50 years....
1. Once parked, don't drive it.....periodic operation can induce more problems than if you let-it-be in most cases.
2. Wash, wax it, completely clean the interior and place an open box on a tray on the floor of baking soda.....it will help absorb moisture
3. Tires.....today's tires will not get flat spots like those built befor 2000......overfill them by 10 psi and this will help to ensure roundness.....if you want to fill them with nitrogen, this is ok as well because it is not prone to temp changes, precludes moisture formation & dosen't leak (larger molecules). If exposed to sun, place large trashbags (contractor type) over them to protect against UV light.
4. Fuel- add fuel stabilizer (I like Marvel Mystery Oil) and fill tank to the top......fuel will begin to "turn" to a varnish like substance beginning at 6 months, with enough fuel stabilizer, this will prevent that. Filling to the top will eliminate as much air in the tank as possible which is a requirement for condensation & "turning" of the gasoline...this helps to stop it. I personally don't like to drain a system because especially using the MMO, it lubricates the "moving parts", which although it still sometimes happens, will help prevent hardening of o-rings, gaskets, injectors, etc.
5. ensure all fluids are topped off, lube/grease everything including graphite in all locks, dry lube in the window seals, etc. Don't bother changing fluids, etc...you will want to do this befor you fire it up upon your return. I would recommend purchasing a radiator anode (zinc) from JC Whitney...they sell for about $10, place it in the radiator overflow...it will act as a sacrificial lamb for the entire cooling system- keeping it corrosion free.
6. Pull the battery.....on a short term, disconnecting the terminals is ok, long term, pull it just in case....especially with temp changes, although very rare, a crack in a battery case undetected can do a lot of damage.
7. Place a plastic bag over the end of the air intake tube or filter...this will help keep bugs/dirt out.
8. If there is a potential for rodents, place a few moth ***** in the engine compartment.....if the storage facility has cats, forget it...the cats will do the work.
When its time to start it for the 1st time, check all the fluids, change the oil (this will provide some lube from the top down in the engine) spin the engine over for 30 seconds...it may or may not start- its ok....wait 1 minute, repeat......the 1 minute is a good cool down for the starter and the 30 second duration will not overly stress any component. By the 2nd or 3rd round, it should start...probably run a little rough, but it will be ok. After 50 miles of driving time, drain all the fluids & replace (coolant may be ok), but definitely engine, tranny, power steering, brake.
Old Nov 27, 2012 | 04:39 PM
jdeacon's Avatar
good stuff^^
Old Nov 27, 2012 | 05:11 PM
MTM Ford's Avatar
I've been wanting to do this with my truck also. I spray about 4 gallons of bar and chain oil everywhere underneath including inside the frame and in all the body panels to help prevent the rust but by the end of winter it's pretty much gone off the frame.
Where about in NW PA are you? Did you rent a space to keep it in or do you have your own garage to store it?
Old Nov 27, 2012 | 07:45 PM
Good stuff man! Thanks a ton! I will definitely be sure to follow this.
I am from Warren, PA which is about an hour and a half SE of Erie, PA. I have a garage of my own. I have known people that have used the same oil for undercoating but, like you said, it comes off after one winter. This summer I did the whole underneath and the inside of some of the body panels with undercoating spray from AutoZone. It seems to be pretty good stuff! It has only been on since summer but still looks like it was done just yesterday. I don't know how it would hold up to the salt on winter roads but from what I've put it through seems to do a really good job!
Old Nov 28, 2012 | 04:27 AM
The carpet squares keep the tread from "sticking" to the concrete floor.
I would use Sta-Bil, not marvel oil.
Old Nov 28, 2012 | 09:48 AM
Here yal are talking about salt and snow and cold temp's. We are sitting in the mid 70s to 80s here so far.. Hell we had the ac blowing on thanksgiving.
Old Nov 28, 2012 | 09:54 AM
No need to rub it in! haha
Old Nov 28, 2012 | 03:46 PM
Yeah, but in the summer your area of TX is hell on earth......
Old Nov 28, 2012 | 06:22 PM
Need4racin's Avatar
Inner panels are where the rust starts. Salt sits inbetween the inner and out fender. All the underside of the body is unpainted. Exterior panels are painted to protect from rust.
Old Nov 28, 2012 | 06:47 PM
str8t six's Avatar
heres a thread i started on this very topic.
https://www.f150online.com/forums/19...-planning.html
ive also decided im going to take the belts off too.
Old Nov 28, 2012 | 10:36 PM
I made sure to get the fender and the bottom of the bed at the back (right above the tailpipe) really well when I did my undercoating for this exact reason.
Good stuff! I didn't come across that. I'm subscribed now though.
