Hard water spots on glass
Old 01-15-2011, 11:06 PM
BRY14661's Avatar
So my last apartment complex i didnt have a garage and the stupid mother ****ing water sprinklers sprayed ALL over the parking lots with hard reclaimed water and i have tried and tried so hard to get the spots off i just cant get them. any suggestions
Old 01-15-2011, 11:18 PM
str8t six's Avatar
0000 steel wool and glass stove top cleaner.
Old 01-15-2011, 11:39 PM
Svets96's Avatar
Try white distilled vinegar in a spray bottle. Go over the glass a couple times.
Old 01-15-2011, 11:49 PM
glc is offline
Clay bar or Barkeeper's Friend.
Old 01-16-2011, 04:18 PM
Super FX4's Avatar
I believe that someone has a window polish for water spots, I just can't remember who sells it. I think some people just use car polish and polish the spots off the windows...
The vinegar method is useless for the spots that have been there for a while. I am also not quite sure on the steel wool method, I saw one guy that hazed his windshield after steel wooling it.
Old 01-16-2011, 04:25 PM
str8t six's Avatar
thats why you have to use 0000 steel wool
Old 01-18-2011, 01:17 PM
RollingRock's Avatar
X2
Super FX4 I believe that someone has a window polish for water spots, I just can't remember who sells it. I think some people just use car polish and polish the spots off the windows...
OneGrand Glass Polish is very good. Griots also sells a glass polish system and pads for DA.
Also, PB PP works very well....
Old 01-18-2011, 02:37 PM
beechkid's Avatar
Household grade vinegar will remove the spots & dissolve any residue....using claybar or steel wool is getting a little aggressive for the initial onset! Typically, it just literally washes off.
Old 01-18-2011, 07:41 PM
glc is offline
Claybar with QD lube won't hurt anything. However, I don't really like the idea of steel wool.
Old 01-21-2011, 12:05 AM
birdshooter's Avatar
Believe it or not you can also use some of the heavy cleaners/compounds out there if you already have some and claying doesn't get it. Meguiar's Heavy cut cleaner or even Ultimate Compound just to name a couple.
Old 01-21-2011, 12:55 AM
jetech00001's Avatar
0000 steel wool with and diluted vinegar works for me.
Old 01-21-2011, 01:23 AM
freekyFX4's Avatar
Lime-Away is made to remove the residue left by hard water.
Old 01-21-2011, 03:31 AM
tbear853's Avatar
Thumbs up
Yeah, I've tried vinager, waxes, polishhes, CLR, etc ...
... there's just one word and a letter will solve those "hard water on glass blues" !
Nothing else works like this or is as easy to clean up afterwards.
SPOT - X
If you've never tried it, your loss.
I got mine at Lowes though Home Depot and the local hardware has it now as well.
Follow directions, you dampen an included "No Scratch" sponge pad with water and then dab some "Spot-X" on it ... makes like a paste ... and rub away spots. You feel the spots at first .... and then as you rub, away they go and the glass is just so slick and smooth then.
http://www.spot-x.net/
What it's made of and how it works ...
http://www.planetnatural.com/site/spot-x.html
Don't bother telling them I sent you ...
... 'cause they don't know me.
Old 01-21-2011, 10:01 AM
glc is offline
Looks like it works very much like a clay bar.
Old 01-21-2011, 06:26 PM
tbear853's Avatar
I have even tried a clay bar, can't touch Spot-X. My '07 had been detailed pretty good when I bought it but the glass was horribly waterspotted, sides, W-shield, back glass, and roof really bad.
I thought no big deal .... until I started trying stuff. It seemed the glass was permanently etched. Then I came across Spot-X. Bought 3 kits thinking I had a mountain of a job ahead of me. After the spots were gone and the glass slick, sold one kit and have one in reserve, and still half of the first kit still on hand.
This stuff ain't clay. It's a very very fine powder like stuff. Any that get's on the paint just rinses off.
Finally a hard water stain cleaner that does not contain dangerous caustic acids. Spot-X uses finely powdered shells to effectively remove water spots caused by mineral deposits, acid rain, salt water, well water, road grime, soap scum and sprinklers. No-scratch formula is ideal for tubs, tile, shower doors, windows and more! Includes a cleaning pad.
How does it work?
Spot-X is made from juglans regia shell. This material is very hard and is used to literally "sand off" the hard water/salt stain, silicate, heavy calcium deposits, lime scale, acid rain spots, soap scum, or any other stain that is on your glass or stainless steel... without scratching it!
Quick Reply: Hard water spots on glass
