product to remove sticky residue
Old Jun 14, 2010 | 05:23 PM
scrap08's Avatar
[IMG][/IMG]
These broke off and now I am trying to get off the sticky tape that held them on? Does anybody know a good product that can get it off?
Old Jun 14, 2010 | 05:55 PM
The tape will have to be pulled and worked off. The glue will come off with Goo Gone or with WD 40.
Old Jun 17, 2010 | 12:37 PM
Saturating an area of the remaining tape with Goo Gone and then working the majority of it off with your fingertips is probably your best bet. Then finish up with a cloth that has been dampened with Goo Gone and you should be good-to-go. I did something similar in removing the faux gas cap from the tail panel of my Mustang and this process seemed to work best.
FYI --be prepared for your fingertips to be very sore after this process -- I felt as if the tips of my fingers had been worn raw after spending an hour or so working on this project.....
Old Jun 17, 2010 | 04:03 PM
Val3ntin0's Avatar
I agree, Goo Gone is good to use in this case. Saturate the sticky parts and work it out with your fingernail. I had to do that when I changed my emblems for customized ones as the glue stayed on the truck and not the stock emblems I had just taken off. Took me a long time to do, probably 1-2 hours per emblem but eventually got it all. The time it takes for you to remove the sticky residue depends on how "sticky" your glue is...
Old Jun 17, 2010 | 06:31 PM
Blown F-150's Avatar
Try 3M Adhesive remover, you can get it from any body shop supply store, even many NAPA's have it.
Old Jun 17, 2010 | 06:32 PM
IR0NS1N's Avatar
WD40 will get it off, its weird but it works real good!
Old Jun 17, 2010 | 07:02 PM
donbeeler49's Avatar
Agreed!
Old Jun 17, 2010 | 09:12 PM
B&WScrew's Avatar
Just did my wife's Taurus last week. Used mineral spirits to get the thick stuff off, then final clean-up with goo-gone on a cloth. By the way. customer servive at AVS (owned by Lund) was excellent. Had a broken visor on both the Taurus'. Sent them a letter with pics and copies of receipts and had new ones (full set) in about a week.
Old Jun 17, 2010 | 10:45 PM
justatruck's Avatar
+1 on the 3M stuff.
Home Depot has it as well.
Old Jun 17, 2010 | 11:31 PM
whitt91's Avatar
wd 40, naptha, ascetone for the super serious stuff, but dont let that sit there for without wiping it off and spraying it with water
