SLOW POWER WINDOWS
Old Dec 27, 1999 | 07:19 PM
Donk21's Avatar
Angry SLOW POWER WINDOWS
My passensger window is very slow going down can anyone help?
97 F-150 4x4 3'lift 35's exaust, bumpers, intake
Old Dec 27, 1999 | 08:35 PM
seacrow's Avatar
Red face
I have the same problem with my girlfriend.
Old Dec 27, 1999 | 11:00 PM
MarkS's Avatar
Wink
seacrow, that seems to be an all too common problem. however the problem usually occurs most often after the wedding.
MarkS
1999 F-150 XLT, 4x4, ORP, SC, SB, 5.4 Liter, 3.73ls, Husky Truck Box, Westin Chrome Nerf Bars, TOFF Spray-in Bedliner, FORD Blue-Oval Hitch Cover, & Superchip.
Old Dec 28, 1999 | 11:29 AM
Indyfan's Avatar
Question
Oh, oh. does that mean I have to get rid of the girlfriend after the wedding?
Old Dec 28, 1999 | 04:27 PM
seacrow's Avatar
Post
MarkS,
My girlfriend must have thought there was a wedding, she's already gained 20lbs. too.
I am sure glad she doesn't know about this site.
Old Dec 28, 1999 | 04:43 PM
REDONE's Avatar
Thumbs up
You just have to take the covers off and lube her up real good.
Old Dec 28, 1999 | 10:17 PM
Donk21's Avatar
Angry
Maybe you can find another site to post these comments. I am wondering if this problem is fixable without replacing the motor!
Old Dec 29, 1999 | 01:46 AM
J-C's Avatar
J-C
Thumbs up
Try Silicone spray on the window track. While you're at it, inspect the track on both sides of the window really well. I had a loose track once and the window was slow because it was moving the track up and down with the window. I just glued the track back to the frame and lubed it with silicone spray. Worked fine after that.
Good luck
Old Dec 29, 1999 | 07:55 PM
Sycoholic's Avatar
Cool
Ford has "mini vent window lube" It's a silicone based goopy stuff. Squeeze it on your window channels and have fun. The stuff works miracles.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old Mar 30, 2000 | 11:04 PM
Xenon's Avatar
Angry
I had NATIONAL CITY FORD of san diego
fix my slow window problem it was part of the due bill!!
THE WORTHLESS FORD MECHANIC JUST SPRAYED some
wd40 and said "see all fix sir"
1 week later im right where i started!!
THIS dealer sucks!!
Old Mar 31, 2000 | 02:53 PM
J-C's Avatar
J-C
Thumbs down
Just because WD-40 is "Made in San Diego" does NOT mean it should be used for everything.
WD-40 is a "water displacer". You need a "dry silicon lubricant" to spray the channels. Complain to the Service Manager that his "technicians" are NOT using the lubricant that Ford recommends. Ask him when they will be trained and certified to work on Fords!
Good Luck.
