cleaning the engine bay??
Old Aug 12, 2008 | 07:34 PM
03fordlariat's Avatar
Hey guys, whats up? my engine bay is getting pretty dirty looking. Is there any tips you guys got on cleaning it?
Old Aug 12, 2008 | 08:05 PM
built54's Avatar
keep water away from the cops... thats about it
Old Aug 12, 2008 | 08:32 PM
ian51279's Avatar
My process:
Get the engine slightly warm, spray down with cleaner of choice, rinse.
DO NOT USE A PRESSURE WASHER!
I use the gentle setting on my hose nozzle. If you don't have one, just let the water flow out of the end of the hose, but turn the pressure down at the spigot.
Finish with dressing of choice.
Old Aug 12, 2008 | 11:01 PM
thanks, Im just scared to hit the electrical stuff and really mess things up. Hey built54, Im right down the road from you. Im down in Arnold Mo.
Old Aug 12, 2008 | 11:16 PM
built54's Avatar
Oh yeah? You have anything done to your truck?
Old Aug 13, 2008 | 03:23 PM
no, its completely stock. Want to do some things though. Is that your blue truck. It looks really cool
Old Aug 13, 2008 | 04:51 PM
billmtx's Avatar
Engine Compartment cleaning. I've done this a few times on various Vehicles I've owned. Before you do anything... Remove the battery and protect Electronic Modules that might be affected by Moisture. Remove the Air Cleaner and cover the Throttle Body.
Warm your Engine... Do NOT Apply Cleaner or wash engine while it is HOT. Spray on your Engine Cleaner and let it do its Magic... you might need to work in the Cleaner with a wire Brush. Then rinse with your Garden Hose.... with a gentle spray that will wash away the grime and dirt. You might need to do a second application. Once done... leave the hood Opened and let the Engine Compartment Air Dry. Install all removed components... battery should be last.
I use an Engine Cleaner from Griots Garage all their Products are great. They also have a Product that makes your Undercarriage and wheel Wells look like new. www.griotsgarage.com
Have fun....let me know if you have any further detailing questions.
Old Aug 13, 2008 | 06:40 PM
Ftruck05's Avatar
My method is to first, Wipe down the bay while dry with a couple of old dry MF's. Then use the blow gun on a compressor and blow out all the crud you have knocked loose. Rewipe the parts that are still dirty. I get a little OCD with it and use a toothbrush to get all the junk out of the crevices on the air filter and tube. Finally I dress it up with what ever "junk"(armor all, F21) I have laying around, I usually get an old MF damp with product and go to town for about an hour. If you do this at least yearly there should never be any need to use any type of engine cleaner and certianly no need to spray the motor with a hose.
Old Aug 14, 2008 | 03:27 AM
I clean my plastics with my Gold Class and dry it and leave it as is, sometimes i'll dress it. Engine it yourself use a cleaner and let it work and lightly rinse it out.
