How cold is too cold....
Old Jan 4, 2008 | 01:04 PM
tiny1's Avatar
I ran out of time and good weather this fall before getting a coat of wax on the beast before winter reared its ugly head. The weather peeps are talking that it may get up to about 50 on Sunday.
I was wondering what would you guys recommend as a minimum temp before breaking out #26 just to help tie things over until April. This will be done by hand and more likely done outside.
Thanks in advance.
Old Jan 4, 2008 | 02:23 PM
risupercrewman's Avatar
Thanks in advance.
Same thing happened to me! I'm thinking about doing the same thing Sunday! I say go for it! I am........
Old Jan 4, 2008 | 03:22 PM
Zaairman's Avatar
Correct me if I'm wrong, but I think that 50* is about the limit, unless you've got a heated garage.
Old Jan 4, 2008 | 03:47 PM
tiny1's Avatar
50 is usually the coldest that I would consider doing any waxing but due to the circumstances I was wondering what others have done.
Old Jan 4, 2008 | 04:07 PM
Zaairman's Avatar
Honestly? Go for it. I would. I've waxed in colder before and it came out just fine.
Old Jan 4, 2008 | 09:06 PM
RollingRock's Avatar
set up and cure time will take longer....I would keep the product indoors until it was ready to be used.
I keep mine in our wine cellar. Joking, kind of.
Old Jan 4, 2008 | 09:12 PM
Rockpick's Avatar
Moderator &
50 to 55 F ambient air temperature is just about the basement level for most products. Like was mentioned, set time will be a bit longer as the delivery chemicals in the mix (water, some solvents) will take longer to flash off in a colder environment.
Also, don't be suprised if you get a smeary end look. It *will* go away but, it may be smeary initially - maybe even up until your next wash or a good rain. The protection will be there before AND after though... #26 is finicky below 60F by my experience.
Old Jan 4, 2008 | 09:31 PM
tiny1's Avatar
RP- I know what you are refering to. I am not overly concern with the final look as the weather forcast is looking like rain by Weds. and it will be getting worse as the week progresses.
Would NXT be a better option then if the temperature does not cooperate???
I know that it is less durable than #26, but for ease would it be worth it??
Old Jan 4, 2008 | 09:53 PM
Rockpick's Avatar
Moderator &
Actually, NXT is *more* durable than #26.
And, in my opinion, NXT would be easier to work with when it's colder. Set times will vary though if you want to go with multiple coats. A minimum of 12 hours of set time before the second coat...
Old Jan 5, 2008 | 01:08 AM
tiny1's Avatar
Thanks for the info and now I just need to wait to see what the weather will do.
