Scratch Advice *PICS*
Old Sep 24, 2007 | 05:18 PM
Favre's Avatar
Scratch Advice Needed*PICS*
Long story short - I was straightening out my truck, I pulled out a couple feet, girl tried to squeeze behind my truck so she didnt have to wait, she scraped my bumper up and ****ed her civic up bad.
IMO its her fault, but who knows with CA laws.
These are pics fresh from the accident:
Old Sep 24, 2007 | 05:21 PM
Favre's Avatar
BTW- Built Ford Tough is true, my bumper doesn't even have a little dent or crease, and the rear quarterpanel on her civic is smashed in like 2 inches.... Just some tiny scratches left on my truck.
I used ScratchX, Meg's Cleaner Wax, and Goo gone and got it looking pretty good.
Old Sep 24, 2007 | 07:11 PM
Jolly_Green_Giant's Avatar
Looks lots better. However if it's deemed her fault I'd still make her insurance buy you a new one.
Old Sep 24, 2007 | 07:36 PM
Favre's Avatar
Oh, no doubt, but it will probably end up being deemed as my fault, Im almost positive that in CA no matter what happens, its the person backing out's fault.
Old Sep 24, 2007 | 08:34 PM
Favre's Avatar
By the way, I was asking for Advice on where to go from her as to working on the scratches even more....Any ideas?
Old Sep 24, 2007 | 09:16 PM
RUSS04's Avatar
Looks like the clear coat is scratched up You cant fix that unless you are a body &fender man Looks like the whole bumper needs to be repainted There are a couple of members that can help you out RP would be one of them Good luck with the repair
Old Sep 25, 2007 | 12:44 AM
Zaairman's Avatar
Just one of the few reasons why I never take my hitch out... But anyways, that broke the clear and looks like it's down to the primer in a few spots... Only way to fix that is to repaint. A cheaper alternative would be to get the touch up paint from the dealer and just use that as a "good enough" fix.
Old Sep 25, 2007 | 07:17 AM
troberts6874's Avatar
yes you prob right...it is going to be your fault(looking at it objectionally from your discription without being there....you say she could not wait, but maybe she thought you pulled in and she went on her way not knowing that you were going to immedately back out after pulling in)...but if her honda is jacked so bad and is going to have 1500 to 5k in damage and your insurance is going to pay, why not claim yours....diffrence in 1500 and 2000 grand doesnt matter to the insurance guys. one car or two cars...doesnt matter to them. if they are going to increase rates...adding your back bumper into the total will not be the straw that breaks the camels back.
Old Sep 25, 2007 | 05:31 PM
Dr. Franko's Avatar
The next step would be wet sanding with 2,000 grit sand paper. Get some soapy water and lightly sand the effected area. Then use the scratch X, or a similar fine polish, to bring the gloss back. Its always best to just sand a little at first and then use the polish to bring it back until you get the hang of it.
Feeling the 2,000 you would not think it cuts much at all but it does.
Old Sep 25, 2007 | 06:04 PM
Shinesintx's Avatar
3M rubbing compound (fine). It does remove some of the clearcoat, but if you take the time, you can get it almost new again. If you use sand paper, it may take off more than you want. Use a soft wet cloth, and prepare to wear out your elbows. The FINE compound can actually remove swirls and restore the finish. Again please remember that it will take a LONG time due to the fineness of the compound.
Old Sep 25, 2007 | 10:54 PM
Dr. Franko's Avatar
Originally Posted by Shinesintx
3M rubbing compound (fine). It does remove some of the clearcoat, but if you take the time, you can get it almost new again. If you use sand paper, it may take off more than you want. Use a soft wet cloth, and prepare to wear out your elbows. The FINE compound can actually you remove swirls and restore the finish. Again please remember that it will take a LONG time due to the fineness of the compound.
Yeah compound or 2,000 either way you are going to take some clear off. Otherwise you won't get the scratches to look any better. I just got more comfortable with the 2,000. One thing for sure you need to know how much cut the product you're using has before going too far. At least he's not working with Black.
Old Sep 25, 2007 | 11:02 PM
RollingRock's Avatar
Your post makes me more bald.
Just sandblast it b/c using the 3M compund and Sandpaper the wrong way is going to do more damage if you are not careful and you only have one crack at it using that method. So if you are hung like a mule, go for it.
The least aggressive way is always recommended. Since you have used ScrachX already I would try something like Optimum Hyper Compound or PoorBoys SSR3, or even Megs #82 with a heavy cut pad before I went to wet sanding.
This is hard to tell based on the photos but it looks like the ScratchX did a great job on the transfered paint. Now you have to get a tad more serious but don't go crazy.
Please look at these photos before you wet sand.
Before
After MY step 1
Finished product, no wetsanding
Old Sep 25, 2007 | 11:21 PM
f-150sport03's Avatar
I will agree that wetsanding can be dangerous, and that you should excercise caution when doing it, but I have something I disagree with...outlined below.
3M makes a lot of great products, but after playing with that fine compound you mention, I really dont like it. Last week, I did a Jeep for a buddy, and it was trail-marred all to hell, swirled, etc. the 3M crap took FOREVER and was not user friendly at all. Then, I pulled out one (Ok, some) of my goodies, and all the problems that could be fixed were fixed in a short order. So, not to be asinine, but 3M Fine cut Compound is NOT what I would reccommend.
Old Sep 25, 2007 | 11:24 PM
I do NOT condone 2k grit for this. By the looks of it, I think he can get away with the SSR series or a set of 83 and 82 or 80. There is no resaon to go sending people off to buy wet-sand equipment when it can all be accomplished with a MUCH less aggressive method. Not to mention, wet sanding takes a bit of finesse, and if you are not comfortable with using high-cut abrasive liquids, using papers will be no easier. I dont mean to be asinine to you, either, but this reccommendation you made was on the strong side for what was needed.
Always remember to stay with the LEAST aggressive method possible.
Old Sep 25, 2007 | 11:29 PM
ThumperMX113's Avatar
Amen! . . at least he's not dealing with Black, I 'waste' so much time figuring out what route to take when dealing with my truck.
