Dirty Dirty engine
Old Feb 22, 2007 | 04:31 PM
gators241987's Avatar
Question Dirty Dirty engine
alrite guys. i have an 06 fx4 screw and ive been muddin a couple of times. i tried washin off my truck, but the mud has stained the some of the tubes and the engine block. what/how would i use to clean underneath my hood? i basically want to make it look brand new. nothing beats a neat lookin underhood truck. i appreciate you guys so much. very helpful forum. rp, your one of the best as well.
Old Feb 22, 2007 | 04:32 PM
diluted simple green
Old Feb 22, 2007 | 04:39 PM
ya, i tried simple green, and it worked a little bit, but not that well. i sprayed it on and let it soak in for about 10 min before washing off. is that the right way to do it or is there another way?
Old Feb 22, 2007 | 05:12 PM
dilute it, try 4:1 first spray it, let it sit for 30 seconds, rub it a little with a little kitchen sponge/pad then rinse it off. Be carefull around the COPs and sparkplugs, the rest of the electrical should be okay to get a little wet, just dont try to soak them.
-Patrick
Old Feb 22, 2007 | 08:50 PM
56chevy00f150's Avatar
also try washing the engine compartment when the engine is not hot. the heat from the motor will cause spotting from the all purpose cleaner.
Old Feb 22, 2007 | 08:58 PM
Ftruck05's Avatar
How bout tire dressing? Spray it on let it sit 5-10min wipe everything then respray and poof brand new engine compartment
Old Feb 22, 2007 | 09:08 PM
1fast4.6's Avatar
yes thats good.. but dont drive anywhere dusty or its twice as bad as it was before
Old Feb 22, 2007 | 09:11 PM
chester8420's Avatar
Quit washing your engine, or you're gonna be chasing missfires.
Old Feb 22, 2007 | 09:16 PM
ian51279's Avatar
Not if you do it right. I've washed alot of engines without one problem.
Old Feb 23, 2007 | 09:35 AM
2stroked's Avatar
The question you need to ask here is, "Do you feel lucky?" I too had cleaned many engines with no problems, until recently when I had problems with my last two ('99 and '02) F-150's. Both developed mis-fires and required some fairly expensive repairs. My dealer doesn't even allow his detail guys to do anything serious under the hood anymore because they had so many problems. Your choice.
Old Feb 23, 2007 | 10:14 AM
ws6_guyscrew's Avatar
I'm with the simple green it worked well for me
Old Feb 27, 2007 | 01:40 PM
SCREWedUPnUTAH's Avatar
I too like a clean Engine! But i just spent $360 to have ford chase down my misfires on my other truck my 01 Screw. That was 1 expensive engine detail!
Old Feb 28, 2007 | 03:46 PM
Yup, it's the risk you take. If you want to, that's fine... There's nothing on these trucks that can't be fixed....
Old Mar 1, 2007 | 06:04 AM
matthewfedex's Avatar
simple green works for me...but like mentioned above...dont over soak your engine when rinsing
Old Mar 1, 2007 | 08:12 AM
TxNessie84's Avatar
I usually just use some kind of all purpose cleaner on a towel to wipe everything down and then follow with some hyper dressing to avoid any potential issues with spraying the engine.
