wax off of plastic mouldings?
Old Nov 26, 2005 | 06:30 AM
jims94vmx's Avatar
just got my o4 back from the second body shop.....they must use a 4 yr old when detailing! alot of places got wax, or whatever they used to buff and polish the truck on some black mouldings. now i have these areas that have turned white! i was going to try back to black to see if i can clean it up. any better solutions? thanks.
Old Nov 26, 2005 | 07:19 AM
jhogan's Avatar
Once you get wax on the moldings it is a PITA to get off. Some guys have tried Magic Eraser and had success. Best to try it in an area that isn't going to be easily seen to see how it works for you. If you search for Magic Eraser, you'll find a couple of threads with pros and cons.
Old Nov 26, 2005 | 02:20 PM
rta108's Avatar
Just rub them down with a regular-old pink pencil eraser. Works like a charm.
Old Nov 26, 2005 | 07:01 PM
Bartak1's Avatar
I tried the pencil eraser and IIRC it didnt work to good for me. The Mr. Clean Magic Eraser kicks a$$ though. Worked great for me.
Old Nov 27, 2005 | 05:37 PM
Boss_429's Avatar
Be very careful where you use the Magic Eraser. It can do un-reversable damage.
Consider a product like 3M's Tar and Wax remover or a product like "Wax Blaster" for serious removal of wax and polish from trim.
Old Nov 27, 2005 | 10:21 PM
khendrix2374's Avatar
I *heard" somewhere that windex and a toothbrush will get way stains off plastic.. I've been meaning to try it, just havent yet.
Old Dec 8, 2005 | 09:42 PM
beavistruck's Avatar
I have tried alot of the things mentioned here but i have to agree with rta108....the regular school eraser works fantastic......leaves no residue....leaves it looking like new....i keep a handfull of the wedge shaped ones in my cleaning supplies. Works like a charm!!
Old Dec 9, 2005 | 12:16 AM
mkinttrim's Avatar
Has anyone used a wax remover that body shops use? Would alcohol work?
Old Dec 9, 2005 | 08:07 AM
jims94vmx's Avatar
the service manager called in an outside company that specializes in doing these things. the back to black i tried did not work. also sometime when the truck was being detailed originally they gouged the right front moulding at the wheel well. looked kinda like the chuck from the drill hit it and took out some of the plastic and made it ruff. about the size of a half dollar. that was the bigger reasont the outside company came in to detail the mouldings. got the call and went to look at the truck and don't know how they did it, but not there anymore. will have to see about the white marks since it has only been a week since their fix. so far so good though. the service dept. in pa is sending the bill to the body shop in ny where the 4 yr old messed it up to begin with......anyway will let you all know about how it looks in another week or so.....
Old Dec 12, 2005 | 08:24 PM
98Lariet4x4's Avatar
I've has pretty good luck with a Dremel and a nylon bristled brush. Time consuming, but effective.
Old Dec 31, 2005 | 12:09 AM
BigBologna's Avatar
Last time I waxed I did it about half in the dark and in a real hurry so I had wax on my plastic too.
Once the wax dried, an ordinary pink eraser took it off like a charm.
Old Dec 31, 2005 | 12:15 AM
supercrewser13's Avatar
I have heard at one time that peanut butter takes it off to not kidding i am serious. I heard this over at another form
Old Dec 31, 2005 | 05:37 AM
Jim03Lightning's Avatar
Add me to the list of satisfied pink pencil eraser users. Works great for me, although sometimes I have to do it twice (do it once, blow/brush off eraser "dust"; repeat).
Also, Back to Black is not intended to remove wax residue. It just restores the dark color & shine to plastic pieces. Use the eraser first, clean the eraser dust off thoroughly, then use B2B.
Old Dec 31, 2005 | 06:55 PM
rmills's Avatar
I think I would've taken it back to them, you didn't get what you paid for. But then again, they could do even more damage!
Old Dec 31, 2005 | 09:45 PM
98Navi's Avatar
Simply take a bottle of handwash solution and rub it on the waxed plastic. It causes no damage and eats the wax right off!
