Cleaning under wheelwells/frame
Old Jun 23, 2005 | 05:53 PM
red_candle's Avatar
How do you all clean underneath and the frame/wheelhousings? Anyone actually sponge down under there, to get the grime off? Was thinking of getting a long-handled brush, kinda like a wheel brush, to get up in there.
With the body looking nice and shiny, I hate having the frame and wheelhousings looking crappy.
Old Jun 23, 2005 | 05:55 PM
05STX's Avatar
Spray the wheel wells with the same stuff you spray on your tires after you wash the truck. They'll be nice and black after.
Old Jun 24, 2005 | 11:17 AM
04Lariat05kr's Avatar
Do you just spray or do you to wipe?
Old Jun 24, 2005 | 11:21 AM
ThumperMX113's Avatar
After Im done washing my truck, I use a different mit to wash my fenderwells and wheels. After that I'll wipe on my tire dressing and just spray some tire dressing on them, the only problem is if you live or drive down dirt roads it can make things messy thats why I stopped doing it.
Old Jun 24, 2005 | 11:59 AM
I wash with a soft wheel bruch the spray with the tire dressing. I then wipe the dressing so it is not running. looks good and cleans up easily the next time.
Old Jun 24, 2005 | 12:09 PM
2stroked's Avatar
Might want to visit our General Care & Detailing forum. Hint, hint.
Old Jun 24, 2005 | 12:16 PM
chrisrud15's Avatar
i just stop and pressure wash under the wheel wells before i know im gonna wash. Then spray some tire shine under there and it will look new again.
Old Jun 27, 2005 | 08:16 AM
EddyG88's Avatar
I do a good amount of offroading and that area always looks dirty. But when its clean up time, the best thing I have come up with is to wash the area the best you can, then use something like Armor-All Foam Tire Shine and Cleaner. The stuff is amazing. You just spray it on and then wipe it down and it brings back a brand new look. You go through a lot of the can doing the all 4 wells and the frame rails, but it looks amazing.
Old Jun 27, 2005 | 08:59 AM
vader716's Avatar
I used a combination of an yard sprinkler left on until the water dripping was clean and some Castrol Super Cleaner sprayed on the tough spots.
Worked great.
Old Aug 20, 2005 | 02:33 PM
ptlmbutler's Avatar
2 words - SIMPLE GREEN.
You wont be dissapointed.
Brian
Old Aug 20, 2005 | 02:53 PM
asinatra's Avatar
Brian
Super Clean is stronger than Simple Green
Old Aug 20, 2005 | 05:26 PM
one eyed willy's Avatar
my process for undercarrage cleaning:
spray with simple green and let soak for a few minutes,spray off and wash rest of truck.then when its all dry just spray the black magic stuff under there real good,looks brand new and only takes a few seconds to spray the simple green on there.
Old Aug 20, 2005 | 05:28 PM
i dont like super clean too much becuase on certain metals it will cause it to discolor,its very bad on aluminum and will cause white rust,so i dont let that stuff get close to my wheels at all.
Old Aug 20, 2005 | 05:44 PM
04 RED LARIAT's Avatar
My process is jack up truck & block the frame, remove wheels and tires, spray super clean under all wheel wells, frame, and rearends.
Take pressure washer with heat on and spray everything under the truck until clean.
Wash the inner side of my wheels and tires while the frame is drying.
Wash rest of truck and air dry.
Spray the wheel wells, frame, rearends, and back sides of tires with hyper dressing.
Reinstall wheels and tires and spray front side of tires with hyper dressing.
Old Aug 20, 2005 | 07:15 PM
HotLap's Avatar
I spray wash the wheel wells and rear frame area everytime I wash the truck and about every 3rd time I take the wash mitt (after every other surface has been washed) and wash the wheel liners - they stay very clean that way. Part of it I'm sure it that here in SoCal we don't get much wet weather (mud, snow, salt) so it stays pretty clean anyways.
