Dealer installed bedliner vs. Independent Shop
Hey everyone! I'm buying a 2013 F-150 Lariat as a surprise anniversary gift for my husband. Is it better to have a bedliner installed by a Dealership or an Indepenent Shop? I'm located in the Dallas-Fort Worth Area and i'm not to sure what the best option would be.
Welcome to the forum!
Most folks on the forum know that I'm a LINE-X dealer.
There's really no advantage to getting the factory bedliner, here's why:
1. Factory warranty is 3 yrs/36K miles; Aftermarket is lifetime.
2. The factory bedliner is aromatic which means it's not UV stable which means it will fade due to UV light from sun. Some aftermarket bedliners are aliphatic which means it's UV stable and will not fade very fast.
3. The factory bedliner is around 65 mils on the floor. A reputable aftermarket dealer will install about 125 mils on the floor.
4. If you have a problem with the factory bedliner, the auto dealer can't fix it, it will go to an aftermarket shop for the repair.
5. If it goes to an aftermarket shop for the repair, the original factory product is not available.
The company that installs the factory bedliner for Ford, Dodge, some Toyota, and the upcoming GM bedliner is Ground Effects, Ltd. (GFX). Last summer, LINE-X acquired GFX. However, the factory product is not a LINE-X product due to contracts that are in place.
She asked about a dealer installed bed liner, not a factory installed one. To my knowledge, dealerships each use different places to install their bedliners. I'd go aftermarket purely because it will be cheaper. A friend's dealer installed bed liner ran him $475, which would have gotten him a better LineX liner with the UV protection.
When you walk into Discount Tire, they all look like tires. Every one of them is made of rubber. Therefore, they are all exactly the same, so it just comes down to markup. Correct or not?
Completely agree with applicator being important, sometimes more important than product. I'd just find out what shop your dealer uses and go from there. Also, you can get a bedliner at any point in the truck's life, so there's no hurry. Don't stress about it!
