Bedliners, Caps, Tops & Lids
Bedrug questions
Old Oct 20, 2008 | 07:37 AM
greencrew's Avatar
Originally Posted by Maxum
Maybe just cut a slit big enough to get the tie down through.
That's how mine was installed.
Old Oct 20, 2008 | 04:52 PM
Arca_ex's Avatar
I just took them off then bolted them back up, but if you can't get them to come off cut a clean slit for it. It'll still look clean.
Old Oct 20, 2008 | 07:49 PM
get a small cutting tool, cut a slot in the head of the bolt, and turn it into a large flat head screw, then order some new hardware from ford
Old Oct 21, 2008 | 11:20 AM
I would un-bolt them, cut minor round holes the sizes of the bolts, re-install then. I would imagine that being the best way for the cleanest look, and help keep any rain/weathering out from under the rug.
Old Oct 21, 2008 | 01:22 PM
bigredtruck06fx's Avatar
bedrug installed. bolts were threaded out so i couldnt remove them. i took a hammer and hammered them closer to bed. install was pretty easy, woman helped me since i hate reading directions. velcro and bedrug=not a good combo. hated when it got on the material
Old Oct 22, 2008 | 12:45 AM
rsbeachbum2's Avatar
You got that thing quick. Can't wait to see it.
Old Oct 22, 2008 | 09:14 AM
Yep, arrived the next day after I purchased it. Autoanything sure is quick
Old Oct 22, 2008 | 12:12 PM
B&WScrew's Avatar
You'll love the Bedrug. It's a neat, clean look. Tough deal with the tie downs. Unforetuneately, too many times, people don't use the proper size torx bit or try to use a phillips bit to get the fasteners out and end up screwing them up. Another good idea is to spray some WD-40 or similar product on the back side of the bolts in case their rusted in.
Old Oct 22, 2008 | 12:17 PM
I guess thats what i get for buying a truck in Mississippi with a bed liner. Before I even started taking out the bolts I could tell they were messed up. Too late to spray anything, bedrug is in, and by the looks and feel of it, its not gonna come up easily.
