Bedliners, Caps, Tops & Lids
Got Toolbox in! (pics)
Old Sep 2, 2006 | 01:10 PM
texasmusic's Avatar
I had trouble with water getting into the box so i raised it up on 2 herculiner coated 4x4's(the water is in the bed cause i just washed it) Theres 4 bolts going all the way through the setup and its pretty snug. Im so glad to have this finished it was alot of rough/frustrating afternoons getting this done.
Old Sep 5, 2006 | 11:27 PM
speedfreak's Avatar
Nice. That's the way I want to go...low profile box mounted up off the floor so I could still sneak a couple sheets of plywood in the bed if I had to. Which UWS box is that and where did you get it if you don't mind me asking.
Old Sep 6, 2006 | 09:39 AM
TruckGasm's Avatar
UWS = very good bang for your buck!
Old Sep 6, 2006 | 07:54 PM
texasmusic's Avatar
I bought the box from Texas Auto Trim, they had it in the shop because someone ordered it but didnt pick it up. I dont reccomend doing buisness through them though because they are just a middle man and you basically pay them to send your truck to a place that specializes in bedliner tint etc. I got my liner done there and they said there was only one type and one color. Then the liner place didnt drill holes in the bed to drain so I took it by there. I saw all the different trucks with color matched and the thinner type of liner which is really what I wanted. Moral of the story: TAT sucks. they also drilled about 5 holes in the box when they mounted it to the bed and they used screws that basically just screwed into the bed liner. The box is a UWS black label. 47 inches wide but will probalby need to be wider to fit nicely if you have a regular bed.
Old Sep 8, 2006 | 02:34 AM
TNoff's Avatar
Cool box!
Old Sep 8, 2006 | 02:27 PM
cvc14's Avatar
Looks good man.. Any better pictures of the box in your truck. I am looking for the same setup as what you have and not sure what box to buy yet.
Old Sep 8, 2006 | 10:25 PM
KiCk aSs FX4's Avatar
looks good Im thinking about getting one
Old Sep 9, 2006 | 12:07 AM
texasmusic's Avatar
https://www.f150online.com/galleries....cfm?num=11531
theres a few pics of what It looks like cosmetically in the gallery. Since I had my drain holes drilled about 4 inches from the front of the bed, and the blocks lined up exactly with the drain holes, The block stopped a little short of going the full length. I used some angle Iron attached to the block and box to fill the gap.
Old Sep 9, 2006 | 12:25 AM
expy03's Avatar
Nice looking setup. I had something similar in a work truck and it came in handy. Only bad thing was the collection of leaves and trash under the tool box.
Old Sep 9, 2006 | 11:38 PM
()smoke()'s Avatar
cool setup
that's a great idea lifting the low-profile box up off the bed like that--i'm thinking like speedfreak because i have the 5.5' bed, so i'm going to work something similar out so i can still get some drywall or plywood underneath
