Replace 04-08 fan blower motor resistor EMTC HVAC
Old Nov 6, 2014 | 01:24 PM
  #91
mrolgren's Avatar
just replaced the component at lunch time.
Thanks for a great thread and write-up!!!
-M
Old Nov 9, 2014 | 02:13 PM
  #92
Maschromm's Avatar
Great tip
It took a little time as I had to get the right tools.
It works just fine Thanks
Originally Posted by mjb1032
This is a VERY easy repair....
If your fan isn't working on all speeds, the fan motor resistor is most likely what's faulty.
There are two types, one if you have automatic temperature control, and one if you have manual.
This is the manual one, Motorcraft part #3F2Z18591AA.
One Ford dealer quoted $22.17, another said $36.00
1) Open the glove box beyond it's stop by pressing the right side in, till the rubber stopper clears the side.
2) This is the part to replace.
3) The screws are 8mm.
4) Slide the part out....it's credit card size.
5) Press the center tab to remove the connector from the part.
Reverse these steps with the new part, and you're good to go!
Old Nov 10, 2014 | 06:11 AM
  #93
mjb1032's Avatar
@Melbrooks and emck,
I wish I had more information to help you guys out.
The Tasca parts sight now has excellent exploded-view diagrams of parts.
I would go there, and hunt for your year and model.
Melb, I suspect it could be the fan motor itself, your next step should be to check if your getting 12 volts to the motor. Unplug the wire connector and check with a multi-meter.
http://www.tascaparts.com
Good luck
Old Jan 12, 2015 | 12:16 PM
  #94
Tightlines's Avatar
Fan speed stuck on high
Thanks for your help. I have a 2009 f150 FX4, with automatic controls. The part was ~$140, plugged it in replaced it and knock wood it works great. Thanks again
Old Jun 27, 2015 | 08:56 PM
  #95
zF150Rocks's Avatar
Worked like a dream
Thanks for the great instructions and photos. Worked like a dream and I now have all my fan speeds again. Cost me $24 for the part you referenced and about 15 minutes of my time. Would have likely cost about $100 at a garage.
Old Jul 19, 2015 | 08:34 PM
  #96
Robgat41's Avatar
06 fx4 -
Thanks for sharing this.. All is back to normal now... Thanks
Old Aug 11, 2015 | 06:59 PM
  #97
Kellsey's Avatar
Thanks to mjb1032 for this thread!
On August 1st, I changed/replaced the lower steering shaft coupler in
our truck. The next day, I drove the truck and the 3 blower levels weren't working for the blower.
I thought I did something under the hood while working on the shaft. Today I Googled, 'F150online 2006 F150
blower doesn't work' and the repair answer came up on the 2nd line for the
'Replace 04-08 fan blower motor resistor EMTC HVAC Aug 6, 2009.' I called Advanced Auto and
they had the part for $24.83. It took me ~15 minutes to complete the repair.
Thanks to everyone for the tutorial and the confidence I got for repairing
our truck and not having to take it to a repair shop.
Old Jun 19, 2024 | 06:00 AM
  #98
handygas's Avatar
Awesome, thanks for the detailed info and pics
