Intermittent Odometer - A Repair
Old Jul 6, 2008 | 10:01 PM
  #136
temp1's Avatar
The harnesses can be removed by pushing or pulling the retaining tabs. Also remove the bolt shown. There are 3 more bolts above the cluster and one to the right that need to be removed.
Old Jul 6, 2008 | 10:11 PM
  #137
temp1's Avatar
The instrument cluster transmission gear indicator has a couple of tabs underneath it that hold it to the instrument cluster. You can feel the tabs move when you press against them ( they move left and right ). I pull down on one side while compressing the tab. You know you have done it correctly when the gear indicator slides down a bit. Then I do the other side.
Re-installation is simple. Align the gear indicator and simply slide it up until it snaps in.
Old Jul 28, 2008 | 09:48 PM
  #138
Bondjs's Avatar
More Kudos for Greg. I bought the a 99 f 150 a month ago with this problem. Probably saved a lot of money on it 'cause it's hard to sell to a stranger with no readable odometer. Took it apart at 5pm tonite KY time), drove it at 7pm. Thanks for the tips, don't know if I would have found it, not being visible to the naked eye.
Thanks again
Old Jul 29, 2008 | 02:32 AM
  #139
ezeakeorage's Avatar
thanks alot for the fix i just recently had this problem arise and its been getting worse i noticed the othere day when i hit the dash a bit it came back on. im gonna try to fix it in the next few days .
Old Aug 1, 2008 | 11:41 PM
  #140
Firefighter110's Avatar
I had the same OD problem with my 2000 XLT. I did the fix which took me about 45 minutes and it works fine now. The whole procedure was very easy.
Old Aug 4, 2008 | 07:04 PM
  #141
Nutdriver's Avatar
Great pics...great advise great site here guys...just did my 99 F150 with the same problem..works great now..
Old Aug 22, 2008 | 10:39 PM
  #142
dusty215's Avatar
Greg, yet another happy customer! Thanks alot. I thought I was probably the only one that had this problem on my 2000 model.
Old Aug 23, 2008 | 06:55 PM
  #143
Smalls101's Avatar
Question A few more questions
I found this forum today on the odemeter, My 2002 Ford Explorer odometer has now gone completely out. By what i have read in this forum the repair seems easy. My husband has no experiance in this and am hoping he can fix the problem himself and save us a lot of money. If someone is willing to, can some one email me the step by step instructions from beginning to end on how to do this so i can give them to my husband. I know i am asking alot of someone. If nothing else i can get some brownie points from him and maybe a dinner too. It would be deeply appreciated.
If someone has any additional pictures that may help, that would be great also.
Old Sep 4, 2008 | 09:46 AM
  #144
sallyboy's Avatar
Hello, Can you please let me know what part/parts you bought to resolve your issue
Hello There,
I have a 1999 F150 and I have the same problem with my odometer and I can not figure out what the problem is. I came across this web site and saw that you had the problem I am explaining. Can you please let me know what part/parts you purchased to resolve your issue and the steps you took.
Thank you & Regards,
Mark
Old Sep 4, 2008 | 12:33 PM
  #145
sallyboy's Avatar
My Bad,
I should have started from page one and saw Greg's resolution before sending my query out.
Old Sep 15, 2008 | 02:57 PM
  #146
johnr59's Avatar
Smile intermittent odometer
Awesome fix. Thanks for all the tips, especially regarding the light switch removal trick. Wouldn't have ever thought of that one. $15.00 for a soldering pen and some rosin core solder and odometer works like it used to. About an hour of my time and one burn on my fnger and all is well!
Old Sep 18, 2008 | 03:13 PM
  #147
smb9143's Avatar
Great fix for odometer!!
This was a fantastic step by step fix for the problem. My odometer had been going in and out for a few years now, and the fix took around 2-3 hours. The rightmost peg on mine was the culprit, just as in the illustration. It has been fixed for 3 weeks now. Be sure to read the thread on the removal of the headlight switch, it is pretty cool and worked perfect. Thanks for this great post (5 years later!!)
Old Sep 19, 2008 | 04:52 PM
  #148
birdst2000's Avatar
It worked!!! great fix thanks. I just took the top dash cover off also, pop off stereo bazel and about 6 more screws. That made it real easy to get at the speedo out.
Old Sep 25, 2008 | 03:07 PM
  #149
F150Europe's Avatar
Thumbs up
Thanks Greg for posting this.
I have a 1999 F150 and this odometer problem is showing up for a month or 2 now. It is not that bad yet but sometimes the odometer won't show the digits, all black.
I will take a look at it.
Thanks again.
Old Sep 30, 2008 | 12:37 PM
  #150
LARABOY's Avatar
hey guys
quick question i wanna change my speedometer to a white face with a blue light up.
has anyone done this kind of job to thier truck if so can you help me out???
thank!!
