How-To: Change your cluster color on 97-03
Here's mine I did last night...thinking about trying incandescent blue bulbs to get rid of the hotspots. Turned out nice though overall I think.
WARNING: Do not put acetone on the gear shift selector piece; it just makes it a clear piece of plastic lol that's why you don't see that piece in my picture. I just painted it black for the time being until I can get another one to replace it :o
I took the dash pieces out, like raptor described in his OP, then took out the cluster. I then removed the overlay from the cluster. On the back of the overlay, over the numbers on the tach, speedo, gas, temp, oil pressure, and battery gauges is a white film that I scraped off with a knife (kinda like scratching a lottery ticket...different than the 97-98 overlays that raptor showed earlier). After that, the green tint was bare and could be acetoned. Then I used 3m spray adhesive and placed it back onto the cluster.
As for the needles, they're all accurate except my gas gauge...I guess I wasn't careful enough putting it back where it should've been. It should be reading full in that picture above - I had just filled up.
How I kept the needles accurate:
Before starting, I took pics of where all the needles were after about 5 mins. of idling the truck. Then I started the disassembly, being very careful not to rotate the needles as I removed them. For the speedometer, I rested it firmly on the little "nipple" that it rests on and pryed it off with a flat head screwdriver...it is very important that you don't rotate the needle while removing it. When I put it back on, I rested it back on that same nipple and placed it back in its place.
Sorry I didn't take pics :o
I used blue LEDs...you'll need to scrape that white film off and the green tint; otherwise, your white LEDs will just be a brighter green than what you have now.
I'd say you should try to find some hyper white incandescent lights to get the white you want without the hot spots...and I'm not sure what the white film is on there for; couldn't tell that it really did anything.
the white stuff prevents the HOT SPOTS its helps defuse the light if you look at the pic above youll see that more light will make it though the top (by the 1)than the bottom zero
