question about this grille
Old Jun 17, 2002 | 01:50 PM
Honster's Avatar
im sure they all look like this, but from this angle i can totally see the black supports in the back of this grille. So my question is, when i buy and install it, will i see these black supports quite clearly, caus ei really dont want to
thanks.
BTW this is a Stull Grille
Old Jun 18, 2002 | 01:53 PM
WLF's Avatar
WLF
Can't speak for the Stull but my Steel Horse looked similar before install and you cannot see the supports. The fins may be a little closer togeather though. I have seen some that you can see the supports so maybe some of the guys here can give you a heads up or a couple of pictures. I am going to detail my truck this week so I will try to give you a picture by the weekend.
Old Jun 19, 2002 | 12:13 AM
Honster's Avatar
cool thank u very much WLF
Old Jun 19, 2002 | 12:16 AM
JA_Stang86's Avatar
Here is my Stull installed
as you can see the supports are not visible. There are a couple more pictures in my gallery from different angles. There is a link in my signature to my gallery. I am guessing that the supports are so visible in that picture because there is light behind the grill so you can see right through it. When mounted there is very little light behind the grill therefore you cannot see behind it too well.
Jeff
Old Jun 19, 2002 | 09:30 PM
Honster's Avatar
thank u very much Jeff, thats what i wanted to see and here.
oh btw, u said insert, doest that mean u put it overtop the exsiting honeycomb grille?
Old Jun 20, 2002 | 09:13 AM
bennett399's Avatar
i have a steel horse on mine, and to answer that question, no they do not go over top of the honeycomb grille. you can trash that thing!
Old Jun 20, 2002 | 10:46 AM
WLF's Avatar
WLF
I have seen grills that install over the honeycomb but you can really see that is what is done and they just don't look that good to me. If you have the painted grill then no problem, just grind off the tabs in the back and remove the old one. Mine was a nightmare. I have the chrome grill and I had to cut around the chrome then grind smooth. It was worth it though in the end.
Like I said, I will try to get some pictures up this weekend...
Old Jun 20, 2002 | 11:16 AM
bennett399's Avatar
yah i hear ya on that one. mine i wouldnt call a nightmare, but it was pain in the azz. i took a chisel and a hammer, that's how i got the clips off mine, and yes i agree, all the work was worth it. i have had the thing on for a year and still to this day i get compliments. who woulda thought?????
Old Jun 20, 2002 | 11:28 AM
WLF's Avatar
WLF
BTW, the one you have pictured has to be installed with the center grill removed. The steel horse is the same.
Old Jun 23, 2002 | 05:30 AM
Honster's Avatar
so how does the grille fit in then if u grind off the locking tabs?
What keeps it in place?
Old Jun 23, 2002 | 12:42 PM
Area 52's Avatar
Honster,
I've got the black stull grill and you cannot readily see the vertical supports on mine. The grill mounts with 4 straight, flat brackets. You drill 4 holes in the frame behind the stock grill shell....2 for the top and 2 for the bottom. I used bolts/nuts on the top and used the supplied screws for the bottom.
The critical aspect of the installation is being very careful when you cut the tabs off of the stock grill shell (surround). I used a Dremel and slowly let it grind away the plastic tabs. If you try to force the Dremel, it may slip on you...so go slow.
PS: Mine fits perfectly...flush up against the back of the grill shell. Also, I painted the metal brackets and screw heads black as I could see these from the front after installing.
Old Jun 26, 2002 | 05:29 PM
Honster's Avatar
thank u area 52 for the rest of the info
Old Jun 27, 2002 | 09:02 AM
sagittarius's Avatar
I have a polished Stull, like the one pictured above. Bought it new on ebay for $102. No, you can't really see the verticle support bars because there is no real light behind, or inside the grille.
No cutting is required to remove the old grille, just a couple of screw drivers. I removed mine from the bezel without breaking any tabs, then sold it on ebay for $40. A fiber cutting wheel in a dremel tool worked great for trimming the bezel.
Old Jun 27, 2002 | 02:21 PM
Honster's Avatar
noted crash, i might keep i might chuck, i'll let ya know if i chuck
