F150 fender emblems-adhesive??
Old Aug 23, 2013 | 11:22 AM
speedstang's Avatar
I removed badges to paint black and im thinkn i need new adhesive to put them back on. Where can i find just the adhesive or double sides factort tape? Ford dealer only?
Old Aug 23, 2013 | 11:27 AM
azmidget91's Avatar
Autozone should have some good black 3M double sided tape, just cut to fit. Don't use cheap double sided tape.
Old Aug 23, 2013 | 11:33 AM
speedstang's Avatar
Thanks. I have a ford dealer 2 min away. Guna run there in a few to see if they can get me just the adhesive. Also need to get my factory door code from them
Old Aug 23, 2013 | 11:34 AM
azmidget91's Avatar
I'm not sure if they sell just the adhesive. Every new emblem I have seen has come with the adhesive on it. Can't imagine they would do just the adhesive.
Old Aug 23, 2013 | 11:39 AM
TruckGasm's Avatar
You can use the 3M double sided tape, but it's sort of thick. Instead you can use 3M Emblem Adhesive available at auto stores like Pep Boys.
Scuff the backside of the emblem with sandpaper before applying the glue for better results.
Old Aug 23, 2013 | 12:22 PM
azmidget91's Avatar
I would highly suggest not using glue...
Old Aug 23, 2013 | 02:32 PM
TruckGasm's Avatar
Why?
Old Aug 23, 2013 | 03:04 PM
kingfish51's Avatar
If you look around, you should be able to find the double sided automotive tape not only in different widths, but different thicknesses.
Old Aug 24, 2013 | 01:44 AM
01 gt f150's Avatar
i would highly suggest not using glue...
x2^
