Satin Black Paint new Best Friend?
Old May 19, 2011 | 06:33 PM
Dasenger's Avatar
I plan on using satin Krylon Satin Black Spray paint alot this summer.
I want to paint:
Door Handles
Wiper Cowl
Heads and tails (for harley)
Maybe the tailgate emblem
and all the other trim that is fading
Will this stay looking good and keep a good texture or do i need a primer as well?
Old May 19, 2011 | 08:35 PM
1997bigredf150's Avatar
All the black you see on my truck is mar-hyde satin black, the flames and bigger pieces were done with a spray gun, smaller pieces sprayed from a shake can. It last but you should not wax it or if it gets wet you want to dry it or it tends to leave water marks. I did not prime nothing but the wheels and bumbers, i even re-painted the whole undercarage and havent seen any issues in the paint.
Old May 19, 2011 | 10:44 PM
gDMJoe's Avatar
Recently went to a auto paint supply shop looking for adhesion promoter to paint emblems and trim. Their recommendation was to just use SEM Trim Black ««« -click-
Part # 39143
Reasons ...
  • only minor surface prep' necessary. *Though I did scuff the surfaces with a ScotchBrite pad and follow-up with isopropyl alcohol.
  • VERY QUICK flash time ( few minutes ). *Hardens in 48hours.
  • advertises that it ... "Offers maximum adhesion on stainless steel and chrome".
We shall see.
Old May 20, 2011 | 12:02 AM
Dasenger's Avatar
OOh ok so I guess i will have to sand some stuff or lay down a primer first. Should i try some Krylon and some of that SEM stuff you mentioned?
Old May 20, 2011 | 10:48 PM
Big Slick's Avatar
Part # 39143
Reasons ...
We shall see.
SEM is one of those companies I've heard great things about, but keep forgetting. Good find.
Old May 20, 2011 | 11:32 PM
russ10screw's Avatar
Yeah I had my truck professionally detailed prior to selling it and they used SEM paint on the undercarriage, hitch, tow hooks, etc. to freshen things up.
Old May 20, 2011 | 11:44 PM
Dasenger's Avatar
oh ok so at like an O Reillys? also i think i want to repaint my saleen grille. I got it used and its looking a little faded, good idea?
Old May 29, 2011 | 09:04 PM
Dasenger's Avatar
Think repainting the Saleen Grille or would that look bad?
Old May 30, 2011 | 09:28 PM
skizriz's Avatar
I have used Krylon Fusion on my grill,front bumper valance,rear window surround,tail lights, and have plans for plenty more.
All I did was clean everything well with simple green, and wipe it down with alcohol to remove any residue.No scuffing or primer.
I painted everything last summer, and it still looks as good as the day I did it.
Stick with the satin black. I tried the gloss and it made everything look painted.
Old May 31, 2011 | 09:25 AM
BLUE20004X4's Avatar
SEM trim black user for life here, it paints very well and matches the factory paint. For plastics, I used SEM plastic or vinyl prep forget the name but it works as the adhesion promoter.
Old Jun 7, 2011 | 08:57 PM
Sarnan's Avatar
For what it's worth, I recently tried "Back to Black" conditioner made by Mothers. Waste of time! I did the wiper cowl, looked great for about a week. 1 month later looks faded again. I've read that "Forever Black" conditioner works well.
Old Jun 8, 2011 | 01:01 PM
Randyl9ll's Avatar
I used satin black Krylon Fusion on my grill, wiper cowl, bed rails and tailgate cap about 3 years ago. They are finally starting to show wear again so I am planning to hit up the wiper cowl and grill again. I had some left over RustOleum Truck Bed Coating from painting my tool box so I hit the bed rails and tailgate cap with it. I'll see how long it lasts.
When I did the Krylon I just cleaned everything real good with Simple Green then went to town with a crap load of light coats.
Old Jun 8, 2011 | 04:11 PM
BlackHD06's Avatar
use SEM. they also sell a plastic prep(thats the name of it) its a surface primer/degreaser spray that works great. not a paint primer like you'd use on metal, more of an adhesion promoter. I have always had perfect results w/ SEM, krylon and duplicolor are very hit or miss w/ anything more involved than spraying semiflat black on a rear end housing.
