2005 f150 grille emblem
Old Apr 16, 2011 | 07:52 PM
fortunedave's Avatar
I'm bought a new ford emblem for my 2005 f150 because the other one was all faded out. Can anyone tell me the easy way to get the old one off and this one on? It came with no instructions. Thx.
Old Apr 16, 2011 | 11:32 PM
jb526's Avatar
I'm no pro, but I replaced the front emblem on my 06. Mine had two bolts holding it from the back, which i accessed by opening the hood. other than that, mine was fairly simple. Hopefully that helps, but I'm not sure if they changed from 05.
Old May 10, 2011 | 04:04 AM
markyoung's Avatar
Wink emblem
Originally Posted by fortunedave
I'm bought a new ford grille emblem for my 2005 f150 because the other one was all faded out. Can anyone tell me the easy way to get the old one off and this one on? It came with no instructions. Thx.
try to go to your mechanic or try searching at ehow. hope it will help. i always bring my car to my mechanic.
Old May 10, 2011 | 10:35 AM
05BlackFX4's Avatar
If you look in my gallery I have pictures of the emblem off and grill being painted. If not I can upload some here.
Basically open your hood, on the backside of the emblem from the inside of the engine bay you will notice 2 bolts holding it in place. Remove the nuts from the bolts and the emblem will slide out from the front of the grill. Replace with the new emblem.
If you wish to remove your entire grill to make it easier, there are bolts that line the top of the grill where it meets the hood. Access to those is also from the engine bay when the hood is open. Its quite easy and you will not need a mechanic to do it. Should take about 10-20 minutes.
heres a picture: (I removed the grill surround as I was painting it, so yours will have the surround still attached)
Old Jun 14, 2011 | 08:59 AM
Deadhead09's Avatar
Ford Emblem
I agree with the previous post, Just open the hood and there are two bolts. My question is: Is their a good site to get a Ford Grille Emblem for a 2006 F150?
Old Jun 14, 2011 | 10:23 AM
bogeyrider63's Avatar
i also need one for my '07. it was hit by a stone.
Old Jun 14, 2011 | 10:08 PM
sam1947's Avatar
www.Tascaparts.com
Old Jun 20, 2011 | 06:56 AM
grille emblem
I finally got it. No bolts on back of mine. It was glued on.
