Bed Rails
Bed Rails
Hey guys, I need some help. I need to buy two new bed rails for my truck. I guess that's what they are called??
It's the black part that goes on the sides of the bed at the top??? I'm wanting the ones that have the holes on the front and rears. I'm wanting to install a CB for the road and I want to use the holes that are in the bed rails but the covers on my bed don't have the holes...
The picture below is what I'm talking about that I need.
Where can I get these? I cant remember the OEM site I bought my tow mirrors from.. It was the same place I think almost everyone here bought theirs from.
The short 5'5 box does not come with factory holes cut in the bed rails....the 6.5' beds and 8' beds have the factory cutouts for the bullrings to be installed....
Your best bet would be to pull the bed caps off your bed and cut the holes yourself. The stake pockets are there just not accessible from Ford's bed rails on the short box.
A dremel will be your best bet. The rails just "pop" off and have several plastic clips that hold them in place. If you break any you can purchase replacements at your Ford stealership for a small fortune (~$30 I believe)
You can also cut the holes while the bed rails are on the truck.
Your best bet would be to pull the bed caps off your bed and cut the holes yourself. The pocket flares are there just not accessible from Ford's bed rails on the short box.
If it were me I would pull the bed rails...cut them (you can put grease on the bottom of the bed rail, then stick back on the truck leaving a nice imprint of the location to cut out) and then paint them with Krylon Fusion. Not only will you have your holes cutout, but your bed rails will be nice and black again.
They probably cut the hole in the stock bed rail themselves....the pocket flares are there...just covered up. Design flaw if you ask me. I may be wrong that the hardware is there for them as well. You might have to do some researching. From what I just searched on Google some say the hardware was there and others say it was just the guts of a pocket flare, and not adequate for using as a solid anchor point for heavy loads.
I know on mine it's just a hole.. I took the bed rails off.. It's good enough to support my CB whip tho.
