Painted my bedrail caps. (Write up/pics)
So I finally got tired of my faded gray bed rail caps. Looked into buying new ones from ford, was about 60$ per side. So I went to checker and dropped about 15 bucks on some Dupli-color textered metalic paint and some prep spray. I also bout some Krylon fusion in flat black. I was worried the duplicolor would not be dark enough so I planned on going over it with the black, however once I got done I liked it so I left it alone. I used the write up in the tech article on how to paint these. I didnt follow it exactly but was close and I think everything came out very well. Here we go.
Started by removing the caps. They come off pretty easy. Broke 2 or 3 clips out of about 40 total.
This shows how faded these were before
Here are the products I used
I used some 220 grit sand paper to rough up the plastic and smooth any scrapes or scuffs I had. Then I sprayed it down with the prep spray and wiped clean. Here it is preped for paint.
Here is the first coat of textured dupli-color
Here is a shot showing a 1st coat and a 2nd coat
Here is the third and final coat
After it was dry I set the rail on the truck to see how it looked and decide if I was going to do black over it.
It looked very good so I decided to not do the black over it. I used a little silicone on the caps where I had broken clips to give a little tighter fit before snapping the caps back on. Here is the finished product.
I didnt do any clear over this but I may regret that later. Im thinking of doing my fender trim as well as my bumper step with this same paint in which case I probably will do a flat clear over it.
Looks great, now wash your truck!
You definitely are going to regret not clear coating
http://www.youtube.com/watch?v=eaEv9wm6gy0
Since Raptorius didn't believe me about the clear coat, I'll show y'all why I suggested it. And for the record I did use Krylon Fusion for PLASTIC
and the clear coat does not make the cowl shiny.
Here's what happens after sitting in the weather for a couple years.
Can you guess which side got the clear and which side didn't?
- NCSU
and the clear coat does not make the cowl shiny.Here's what happens after sitting in the weather for a couple years.
- NCSU
Yes I pulled it off to paint it also.
[QUOTE=Yogi.kudos;4110640]Looks great, now wash your truck!
Yeah I think your right. I may get some clear and do a coat with them on the truck.
So thats what it looks like with caps removed huh. When I did mine I masked my bed off and went to work. I didn't use clear coat either and its actually held up perfectly fine.
https://www.f150online.com/forums/ar...nting-how.html
I hate how you have to have the rail caps on....I wish it was smooth on the rail so you could go without them..would look so much cleaner.
Has anyone had their bed rail caps coated with Line X when doing the bed? I have been wondering if this could be successfully done.
